Either. You select which you want. You can go 2hi, 4 auto/full, or 4 hi locked, or 4 low. It's the best of both worlds, really.So with selec trac can you still manually control 4wd or is it just always on and kicks in when needed.
same question regarding trac loc.
thanks !
LSD is on at all times.So with selec trac can you still manually control 4wd or is it just always on and kicks in when needed.
thanks !
Have no direct exp with the JL LSD but it may be of some value to google research any problems that may be associated with the system before purchasing.Thanks. This set up looks to be exactly what I need. Coming from a Tacoma PRO which has been disappointing in snow.
We get a ton of snow and basically drive through often unplowed snow and ice daily for 4 months. Lockers are basically useless for my application.
running Hakka r2’s. which I’ll have to get re wheeled for the Jeep. Unfortunately can’t run studded as I need ride in some roads they not allowed.
