Is there an aiming adjustment dial for OEM LED fogs?
Bingy
Bailey, Colorado
2018 Jeep Wrangler Sahara JLU
Curious if there is an ability to aim an LED OEM fog housing in an aftermarket bumper? Seems I have one aiming a little higher than one side and would like to level them out. Hoping there is an adjustment dial or screw on the housings.
Thanks for the help...
Rhinebeck01
Multiple places..
@Bingy
I'm at a different location then my JL right now so can not look.. but
On the JK there is a say dime size access hole on the bumper, directly below each fog light. My guess is with the JL it is similar..
You just access the fog light adjuster screw for each fog light thru each access hole and make the adjustments.
Turning the adjuster screw clockwise sets aim down and counter clockwise aim goes up. With a JK, you use a Phillips head screwdriver to do the adjustment.
Bingy
Bingy
Bailey, Colorado
Success! There is an adjustment dial. It is a hex fitting. Issue solved. Thank you...
Terpsmandan
Penn Yan
Dead thread revival. I saw a phillips head that would fit a screwdriver. I have not checked it yet. it is on the lower right side of lamp if you are looking from behind.
