Yellowknife
Agreed. So in addition my understanding is that Ordinary cars in general can experience undercharged batteries if repeatedly driven short distances only, particularly in cold weather.More starts with less charge time.
In sub-zero weather, lead-acid batteries require about 15 minutes of driving to internally warm up enough before they can accept a good charge. Voltage regulators are calibrated to start charging at higher voltage when cold, then drop as the battery warms up to prevent electrolyte loss.
In addition, having high drain accessories on like a rear defogger, seat warmers and heater blower etc. leaves less alternator output available for charging the battery.
Basically cold starts/short trips can take more charge from the battery than youâre replenishing up here in particular as I've seen for decades first hand. Eventually, the draw of accessories, cold starts etc. cause a shortfall in recharging until the battery hits a critically low level, and the car wonât start.
As expected some will argue otherwise. This is from my first hand experience with countless examples of it. Same with folks up here who don't run their engine's long enough to raise the oil temp enough to remove condensation in extreme cold. They end up with water in their engine's and complete engine failures even though they're doing regular oil changes.
