Is there a way to stop the sway-bar from reconnecting above 18 mph?
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Title says it all, is there a way to prevent the sway-bar from automatically reconnecting at 18 mph?
Vinman
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
I can’t be the only person annoyed by the sway bar re-connecting by itself.
chacomaya
Portland, OR
2018 JLUR, 2013 VW Golf R, 2016 KTM 1290 Super Duke GT, 2015 KTM 500EXC
Totally hate this "feature", too. Watching for knowledgable replies...
MarkY3130
Denver
2019 JLUR
From Tazer instructions
• Set Sway Bar: If the Electronic Sway
Bar has been removed, you can use this setting to delete the warnings. You can also use this feature to be able to drive with the sway bar disconnected at any speed or 4WD range. Simply shift to 4WD, press the button to disconnect the sway bar, and once it’s disconnected, enter the Tazer JL Mini JL settings menu and set the Sway Bar off. It’ll remain disconnected until you set it on again.
Vinman
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Thanks for the reply folks. I already have a the Flashcal so hopefully it can also defeat the swaybar lock like the Tazer.
Thanks again.
chacomaya
Portland, OR
To "set it on again", do you have to use the Taser settings menu, or just the button on the dash?
UNC Rubicon
Bret
Kernersville, NC
2019 Billet Silver JLUR
If you remap one of the cruise control buttons for SwayKill, you can just use that button to disconnect and reconnect. 2WD, 4WD, doesn’t matter.
chacomaya
Portland, OR
Excellent! Thank you.
1996cc
Oregon
21 JLUR 392
Or use one of the EVO options to bypass the factory systems. Wither a manual knob or air actuated.
