Is there a video on how to completely remove the soft top?
Thomas
Tampa
Wrangler JL Sport S
Youtube is filled with videos on removing the panels and putting the top down but what about actually dismounting the soft top from the Jeep?
Buckster
Bradenton, FL
'19 billet silver JLUR '16 Grand Cherokee Overland
Power Generation
That's pretty much it.
It can be done solo, but it's like wrestling an octopus to get the top off or back in place. Infinitely easier with a helper.
DHW
Atlanta
2018 Rubicon
Attorney
This is true.
If you still have the soft top cover, put it on the top while it's folded back and it's much easier to handle when actually lifting it off the Jeep.
Konamonster
Jon
Boulder, CO
2021 JLU Rubicon - Had 2018 JLU Sahara
Note from experience: Make sure you lock it in folded down position on each side!! If not, when you pull it off the frame, the springs will rotate the mechanism and pinch your fingers between the tube supports.
JPAloha
Calgary
2019 JL Rubicon 2 door
Accredited Financial Planner
As mentioned above, lock the mechanism and add a couple of straps around the roof material and frame arms to keep it from opening up as you lift it off. Buy a couple of long arm brackets to hang it on the garage wall.
The Fixer
North Jersey
Teacher
Agreed! My wife got her JLU in May of '18. I built a wood cart for the hard top and we put the soft top on the next day, no issues. When my son and I removed it in the fall we forgot to wrap the protective cover around it and forgot to lock the latch mechanism. What a disaster!
Spring and fall of 2019 was much smoother with install and removal LOL.
Extreme Terrain
