Is the Bestop Sunrider being slightly lop sided an issue?
DZZNUTTZ
Phil
NYC
Jeep JL Sahara
I just purchased a Black twill Sunrider for JL from Rubitrux.com. I took a look at the directions and YouTube videos and installed the sunrider carefully, but on the driver's side the Sunrider is sticking up more than the passenger side. Just in case I installed it a second time, but same thing. I water tested, but it seems like it doesn't leak. However it doesn't look proper. Any suggestions or is this ok?
AMKRubicon610
Andy
PA
2021 Wrangler JLUR 6 SPD
CPA
Mines not 100% perfect. Looks kinda like yours, not noticeable at all unless you’re up high looking down on it. I figured with the fact that the roof is removable, there’s gunna be some minor play in fitment. Mine doesn’t leak either, enjoy it!
DZZNUTTZ
DZZNUTTZ
Phil
NYC
Jeep JL Sahara
Got it. Thank you@AMKRubicon610
wolfdog
George
Southern Massachusetts
2006 Yamaha FJR1300, 2021 JTO, 2018 JLU Sahara
Maritime Artisan, Mayflower II
Send Bestop your pics I think they'll b honest with you? Great company and you'll love the Sunrider it's just great. So much better thn dealing with panels and worring about to drag th3m along or leave "em home in case of rain! Live in N.E. left it on all winter this year, no complaints!
Go Jeep!!! and Bestop!!
DZZNUTTZ
DZZNUTTZ
Phil
NYC
Jeep JL Sahara
Will do. Agreed, so much better without the hassle of the freedom tops.
DZZNUTTZ
DZZNUTTZ
Phil
NYC
Jeep JL Sahara
Jeep Wrangler JL Is the Bestop Sunrider being slightly lop sided an issue? 20210610_171809
Anyone @Bestop out there? I keep getting this message on your website.
Jeep Wrangler JL Is the Bestop Sunrider being slightly lop sided an issue? Screenshot_20210611-182418_DuckDuckGo
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
If your concerned about the raised back edge don’t be, there is material fastened into that rail that runs along the back and you have to remember that it presses against the seal along the back and the material will flex and stretch when wet and it will never be as even as the freedom panels as it’s not rigid at least from the material side, as long as it does not leak Its fine.
Heres a test to do after say you wash it, while the top is still damp loosen the latches and raise it like opening but not all the way then let it dry all the way and after dry look at that area of concern I’m betting it looks better and as you latch it watch how the material stretches and after a little time it stretches back out, it’s gotta stretch.
But maybe I’m not seeing what you are seeing ..
DZZNUTTZ
DZZNUTTZ
Phil
NYC
Jeep JL Sahara
If your concerned about the raised back edge don’t be, there is material fastened into that rail that runs along the back and you have to remember that it presses against the seal along the back and the material will flex and stretch when wet and it will never be as even as the freedom panels as it’s not rigid at lest from the material side, as long as it does not leak Its fine.
I appreciate the info @WranglerMan Looks like it doesn't leak, so I'll work on my OCD.
Bestop
Peak Sponsor (Level 2)
The Bestop Team
Louisville, CO
2010 JKU
Hey @DZZNUTTZ
Yes we're out here. I can't see the lopsidedness that you're referring to exactly but I can trust you that it's there. As @WranglerMan mentioned, the seal is designed to be compatible with multiple years of hardtops so it will often rest on top as you have. My recommendation is just to run it and see if there's any performance issue. If you're concerned and want further validation I would email our CS Team, though they are a bit backed up this time of year.
Lee
- the Bestop team
www.bestop.com
Rhinebeck01
Multiple places..
@DZZNUTTZ
I like @Bestop am unable to say much after viewing your pics. Not the right angle, etc..
I have installed, 4 Bestop Sunrider for JL's so far...
I also have viewed one SR that had the Z-clip broken and how that leaves the install/the look of the installed SR.
If you want another opinion and to give Bestop another look so to speak...... is there any chance you can take a few more pics and post here.
I would like to see one straight down on the installed SR and then one from directly behind the JL ... with the camera being up about 3' and about 4' from the SR. That and just a few more pics in general...
About the warranty..... Bestop will not warranty the SR if you bought it used... even if it was only a few days old and you bought it used...
As the original SR buyer though, do know that Bestop has your back so to speak and will be there for you if the SR has issues. They back their product!
I had a Zclip break loose on a Twill, SR after over 35,000 miles of use / almost 2.5 years use.... and I used it alot and Bestop sent me a new one for free .... with no hassle or push from me nor cost by me when my Zclip broke off.
I wish all companies stood by their product offerings like Bestop does theirs..
p.s. With what I am seeing by the pics you posted your SR is aok and there is no issue..
DZZNUTTZ
DZZNUTTZ
Phil
NYC
Jeep JL Sahara
Hey @DZZNUTTZ
Lee
- the Bestop team
www.bestop.com
Thanks Lee, I did the water test, seems ok. I'll monitor and also upload another photo from a different angle as Rhinebeck01 suggested. I keep getting this error when trying to submit an email on Bestop's website.
Rhinebeck01
Multiple places..
@DZZNUTTZ
I found it best to just call Bestop's Customer Service number. They are in Colorado... With that said call 1-800-845-3567 at say 11am EST and you will get through.
I am sending you a PM... Do read .. 8-)
DZZNUTTZ
DZZNUTTZ
Phil
NYC
Jeep JL Sahara
@DZZNUTTZ
I appreciate it. Thank you.
