Is the 84:1 Crawl Ratio of the Manual Transmission Low Enough?
Billy
Bend, OR
1997 TJ, 2022 JTRD
Just wear and tear due to friction and heat. I recommend avoiding it.
DanW
Indiana
I believe 29mph is the maximum recommended speed in low range.
wanderer
Ralph
Carlsbad CA
Engineering Geologist
I like a manual on hills that you don't make and have to back down
foo.c
2017 Ford Raptor, 1997 Lexus LX450
It will be ok most of the time, but after adding weight and tires you may find yourself stalling more. When I started towing a little trailer off-road was when I said no more manual.
SS_Syndicate
Jay
Ohio
sevenslotsyndicate.com
'13-JKUR, '16 KL Cherokee, '17 4-Runner, '67 Kaiser M715
Engineer, Blogger, Vlogger
With the 8sp, it shouldn't be too bad, stay in 4lo
The OP was asking about the manual transmission and that is what we have. I have no intention of ever owning an automatic anything as long as there is a manual option.
SS_Syndicate
Jay
Ohio
Is there a problem driving in 5th or 6th in low?
As @Billy mentioned and then @Dirt32 clarified a bit... The only issue is heat and wear. In higher transmission gears the the output side of the transfer case is spinning pretty quickly (you can hear it whine). This of course is assuming you changed gears to go faster and are not at idle.
LOL, in 5th gear (4LO) and just a tick over 2k RPMs we are going 10 MPH. Now, a 3.21 geared JK/JKU with a standard T-case (2.72) would be going over 20MPH at ~2k RPM.
This hasn't been an issue for us at all, but I build our overland trailer pretty light. Like I said earlier, gearing is key to off roading a manual. Another advantage though is more mass in the flywheel. IMO the JK/JKU could have used a little heavier flywheel, luckily aftermarket clutches are out now that do this. Out factory clutch is still kicking it, but when the time goes this will be a big factor in the replacement we use.
DanW
Indiana
Yeah, I don't think I've even been 20mph in low range in my JK. Maybe 10 or 15, tops. Good to know the max recommended, though.
