sandy.h
Will this solve your issues? Maybe. Regardless, it's a necessary first step. I'm shocked of no reports at your end of the dealer not testing the batteries.
I replaced the aux battery two days ago. However, twice today I got into my jeep and tried to start it and engine doesn’t turn on. (Twice out of the seven times I’ve started my jeep today) Electronics turn on though, and it goes into “run” and stays stuck in run. Won’t let me shut the jeep off completely. Messages on the dash are:
“Service Electronic Stability Control”
and
“Service transmission. Continue in D. Do not shift or turn engine off until you have reached desired location. You may not be able to shift again until serviced.”
If I wait about five minutes without touching anything, the messages disappear and it shows the speed. I press the stop/start button and engine turns on. These are problems that have happened before but it could happen once then won’t happen again for months. I’m wondering if I could have messed up when installing the new aux battery (I did it myself and it was quite difficult). I thought it might be a blown N3 fuse but I’m assuming if that was the case, the engine won’t turn over at all.
One more thing I forgot to note though! After I replaced the aux battery, the jeep would turn on, engine on, dash and display would turn on. Then all of a sudden dash and display turn off, but jeep is still on and running. When I replaced the aux battery I took the PDC apart, I thought maybe some fuses got messed up, they were all good. I then proceeded to tighten the four bolts holding the PDC together. Tried starting it again and it worked fine. Took it for a ride, no problems. Now two days later, we got problems!
