Fox has 3.0s that bolt onLike the title says, is 2.5 the biggest body that will fit on a JL?
If someone is running a FOX or KING 2.5, can you share some insight.
Where are the clearance issues (if any)
Any idea what the collapsed & extended lengths are on your shocks?I am running the Fox 2.5 4"-6" shocks front and rear. There are a couple issues to be aware of. On full droop, if you are using the full 12" of travel the shock body will hit the frame. This can be fixed by moving the bottom shock mount out 1-2". I used the Metalcloak bracket to do this. I also had to trim the back of the shock tower flange because the axle moved back far enough that the shock body made contact. The shocks work really well you will just need to flex it out and see where your contact points are.
Front: 18.34, 30.51Any idea what the collapsed & extended lengths are on your shocks?
