jmccorm
Good points all the way around. And throttle will be even more disconnected from the accelerator because the vehicle is rev-matching into it's new gear.This may be a programming issue where, in your instance, it's not optimal and really shows an issue.
Let me share some of the more recent logs. The times, at least, are improved now that I've optimized the tire size:
Log Excerpt #1: Flooring the accelerator pedal from 36 MPH (transmission shifts from 6th to 3rd), acceleration 0.9 seconds later:
96430.5 ACCL: 9% (VALVE 10%) RPM: 1536 GEAR: D6 DOM: 7603.6mi MPH: 37.19
96430.6 ACCL: 9% (VALVE 9%) RPM: 1525 GEAR: D6 DOM: 7603.6mi MPH: 37.11
96430.7 ACCL: 10% (VALVE 9%) RPM: 1528 GEAR: D6 DOM: 7603.6mi MPH: 37.09
96430.8 ACCL: 10% (VALVE 9%) RPM: 1537 GEAR: D6 DOM: 7603.6mi MPH: 37.08
96430.9 ACCL: 10% (VALVE 10%) RPM: 1530 GEAR: D6 DOM: 7603.6mi MPH: 37.08
96431.0 ACCL: 10% (VALVE 10%) RPM: 1534 GEAR: D6 DOM: 7603.6mi MPH: 37.06
96431.1 ACCL: 10% (VALVE 11%) RPM: 1538 GEAR: D6 DOM: 7603.6mi MPH: 37.13
96431.2 ACCL: 10% (VALVE 11%) RPM: 1535 GEAR: D6 DOM: 7603.6mi MPH: 37.09
96431.3 ACCL: 10% (VALVE 11%) RPM: 1531 GEAR: D6 DOM: 7603.6mi MPH: 37.04
96431.4 ACCL: 10% (VALVE 11%) RPM: 1529 GEAR: D6 DOM: 7603.6mi MPH: 37.05
96431.5 ACCL: 53% (VALVE 20%) RPM: 1528 GEAR: D6 DOM: 7603.6mi MPH: 37.02
96431.6 ACCL: 77% (VALVE 25%) RPM: 1587 GEAR: D3 DOM: 7603.6mi MPH: 37.10
96431.7 ACCL: 80% (VALVE 34%) RPM: 1673 GEAR: D3 DOM: 7603.6mi MPH: 37.16
96431.8 ACCL: 80% (VALVE 38%) RPM: 1761 GEAR: D3 DOM: 7603.6mi MPH: 37.26
96431.9 ACCL: 84% (VALVE 42%) RPM: 1976 GEAR: D3 DOM: 7603.6mi MPH: 37.27
96432.0 ACCL: 88% (VALVE 46%) RPM: 2322 GEAR: D3 DOM: 7603.6mi MPH: 37.17
96432.1 ACCL: 92% (VALVE 51%) RPM: 2758 GEAR: D3 DOM: 7603.6mi MPH: 37.15
96432.2 ACCL: 92% (VALVE 57%) RPM: 3168 GEAR: D3 DOM: 7603.6mi MPH: 37.19
96432.3 ACCL: 92% (VALVE 68%) RPM: 3324 GEAR: D3 DOM: 7603.6mi MPH: 37.26
96432.4 ACCL: 92% (VALVE 76%) RPM: 3581 GEAR: D3 DOM: 7603.6mi MPH: 37.86
96432.5 ACCL: 90% (VALVE 83%) RPM: 3575 GEAR: D3 DOM: 7603.6mi MPH: 38.57
96432.6 ACCL: 89% (VALVE 89%) RPM: 3543 GEAR: D3 DOM: 7603.6mi MPH: 39.34
96432.7 ACCL: 88% (VALVE 91%) RPM: 3586 GEAR: D3 DOM: 7603.6mi MPH: 40.28
96432.8 ACCL: 88% (VALVE 91%) RPM: 3594 GEAR: D3 DOM: 7603.6mi MPH: 41.04
96432.9 ACCL: 88% (VALVE 92%) RPM: 3639 GEAR: D3 DOM: 7603.6mi MPH: 41.52
96433.0 ACCL: 87% (VALVE 90%) RPM: 3693 GEAR: D3 DOM: 7603.6mi MPH: 42.03
96433.1 ACCL: 87% (VALVE 91%) RPM: 3731 GEAR: D3 DOM: 7603.6mi MPH: 42.48
96433.2 ACCL: 87% (VALVE 92%) RPM: 3807 GEAR: D3 DOM: 7603.6mi MPH: 43.28
96433.3 ACCL: 88% (VALVE 93%) RPM: 3855 GEAR: D3 DOM: 7603.6mi MPH: 44.00
96433.4 ACCL: 89% (VALVE 93%) RPM: 3918 GEAR: D3 DOM: 7603.6mi MPH: 44.55
Log Excerpt #2: Flooring the accelerator pedal from 50 MPH (transmission shifts from 8th to 7th, then 7th to 5th, and then shifts from 5th to 3rd), acceleration 1.1 seconds later:
96742.2 ACCL: 22% (VALVE 23%) RPM: 1750 GEAR: D7 DOM: 7605.7mi MPH: 50.56
96742.3 ACCL: 21% (VALVE 23%) RPM: 1753 GEAR: D7 DOM: 7605.7mi MPH: 50.60
96742.4 ACCL: 21% (VALVE 23%) RPM: 1755 GEAR: D7 DOM: 7605.7mi MPH: 50.56
96742.5 ACCL: 20% (VALVE 22%) RPM: 1752 GEAR: D7 DOM: 7605.7mi MPH: 50.61
96742.6 ACCL: 20% (VALVE 21%) RPM: 1751 GEAR: D7 DOM: 7605.7mi MPH: 50.55
96742.7 ACCL: 20% (VALVE 21%) RPM: 1752 GEAR: D7 DOM: 7605.7mi MPH: 50.59
96742.8 ACCL: 19% (VALVE 22%) RPM: 1755 GEAR: D7 DOM: 7605.8mi MPH: 50.59
96742.9 ACCL: 20% (VALVE 21%) RPM: 1755 GEAR: D8 DOM: 7605.8mi MPH: 50.59
96743.0 ACCL: 19% (VALVE 21%) RPM: 1757 GEAR: D8 DOM: 7605.8mi MPH: 50.54
96743.1 ACCL: 19% (VALVE 21%) RPM: 1782 GEAR: D8 DOM: 7605.8mi MPH: 50.54
96743.2 ACCL: 55% (VALVE 24%) RPM: 1799 GEAR: D8 DOM: 7605.8mi MPH: 50.55
96743.3 ACCL: 80% (VALVE 37%) RPM: 1891 GEAR: D7 DOM: 7605.8mi MPH: 50.62
96743.4 ACCL: 83% (VALVE 41%) RPM: 1892 GEAR: D5 DOM: 7605.8mi MPH: 50.70
96743.5 ACCL: 81% (VALVE 47%) RPM: 1882 GEAR: D5 DOM: 7605.8mi MPH: 50.72
96743.6 ACCL: 82% (VALVE 51%) RPM: 1984 GEAR: D5 DOM: 7605.8mi MPH: 50.81
96743.7 ACCL: 84% (VALVE 55%) RPM: 2237 GEAR: D5 DOM: 7605.8mi MPH: 50.89
96743.8 ACCL: 86% (VALVE 60%) RPM: 2485 GEAR: D5 DOM: 7605.8mi MPH: 50.88
96743.9 ACCL: 89% (VALVE 68%) RPM: 2818 GEAR: D5 DOM: 7605.8mi MPH: 50.99
96744.0 ACCL: 90% (VALVE 78%) RPM: 3169 GEAR: D3 DOM: 7605.8mi MPH: 51.16
96744.1 ACCL: 86% (VALVE 87%) RPM: 3587 GEAR: D3 DOM: 7605.8mi MPH: 51.28
96744.2 ACCL: 83% (VALVE 90%) RPM: 4135 GEAR: D3 DOM: 7605.8mi MPH: 51.38
96744.3 ACCL: 83% (VALVE 85%) RPM: 4615 GEAR: D3 DOM: 7605.8mi MPH: 51.57
96744.4 ACCL: 80% (VALVE 85%) RPM: 4714 GEAR: D3 DOM: 7605.8mi MPH: 52.35
96744.5 ACCL: 81% (VALVE 85%) RPM: 4689 GEAR: D3 DOM: 7605.8mi MPH: 52.99
96744.6 ACCL: 80% (VALVE 85%) RPM: 4721 GEAR: D3 DOM: 7605.8mi MPH: 53.57
96744.7 ACCL: 83% (VALVE 87%) RPM: 4775 GEAR: D3 DOM: 7605.8mi MPH: 54.28
96744.8 ACCL: 81% (VALVE 85%) RPM: 4824 GEAR: D3 DOM: 7605.8mi MPH: 54.96
96744.9 ACCL: 80% (VALVE 87%) RPM: 4883 GEAR: D3 DOM: 7605.8mi MPH: 55.59
96745.0 ACCL: 80% (VALVE 88%) RPM: 4933 GEAR: D3 DOM: 7605.8mi MPH: 56.30
96745.1 ACCL: 78% (VALVE 88%) RPM: 4978 GEAR: D3 DOM: 7605.8mi MPH: 56.93
96745.2 ACCL: 78% (VALVE 89%) RPM: 5050 GEAR: D3 DOM: 7605.8mi MPH: 57.64
96745.3 ACCL: 77% (VALVE 87%) RPM: 5090 GEAR: D3 DOM: 7605.8mi MPH: 58.31
Overall? I think I share many of your thoughts. Well said! For better or for worse, this would tend to leave it at Jeep's discretion whether they wanted to pursue or not. I won't hold my breath, but I'll hope for product improvement.
