Feenix_ST
My 15' Cherokee had the same switch set up and that controlled the accent lighting however in my new JL it doesn't do anything. Either mine is broke or can't notice anything.
Dims Floor and drink holders I believe..I found the one on the right dims the dash lights, while the one on the left only seems to control the floor lighting. What the heck? Is there anything else that left dimmer does? Weird.
My wife and I both prefer bright dash and subdued touchscreen and I see no way to achieve this without turning off the touchscreen completely. I wish the lighting had a continuous adjustment instead of such a bright to dim step. I'm sure I could find my sweetspot.I'm curious if my 8.4 inch touchscreen will be dimmable separate from the dash lights. While night driving I like bright dash lights but subdued touchscreen. All I see in the manual is that I can turn the touchscreen off.
Change the brightness setting for when the headlights are on. In the UConnect.My wife and I both prefer bright dash and subdued touchscreen and I see no way to achieve this without turning off the touchscreen completely. I wish the lighting had a continuous adjustment instead of such a bright to dim step. I'm sure I could find my sweetspot.
How does it work? I can see the slight light in my handles change but I see no light on my floor. Sport S by the way. Unless my floor lights don't work and I've just now noticed. Guess you can't miss something you never knew you had.Yeah, it controlls the footwells and cup holder lighting. But the way it works is really odd.
Rubicon may have more lighting, I think I read that somewhere a while back. Maybe check the owner's manual.How does it work? I can see the slight light in my handles change but I see no light on my floor. Sport S by the way. Unless my floor lights don't work and I've just now noticed. Guess you can't miss something you never knew you had.![]()
I did find that setting on the UConnect, but it's grayed out for headlights on (value of 5 so it's set midway) both on auto and manual settings so I can't change it. I can only change it for when headlights are off.Change the brightness setting for when the headlights are on. In the UConnect.
My Sport has the light on the floor, but you have to turn the right lighting knob all the way up until the overhead interior light comes on, which also makes the floor light come on. Then moving the left scrolling light up and down, I can't tell any difference with the lighting. Not sure what it's supposed to do.How does it work? I can see the slight light in my handles change but I see no light on my floor. Sport S by the way. Unless my floor lights don't work and I've just now noticed. Guess you can't miss something you never knew you had.![]()
Did you try and change the settings with the headlights on?I did find that setting on the UConnect, but it's grayed out for headlights on (value of 5 so it's set midway) both on auto and manual settings so I can't change it. I can only change it for when headlights are off.
But what I didn't do that my son did last night was to have headlights on, switch the Uconnect display to manual setting and change the headlights off setting. Even though it's backwards, we were able to dim the UConnect using the off settings and the dash stayed at the brightest setting.Yes, tried both on and off
