Shots
Everything I read while researching lifts had Dynatrac rated the highest for comfort for kits that replaced both the springs and shocks. I couldn't find a single review where someone was unhappy with it. That says a lot, when you can't find any unhappy buyers. Usually you'll get at least a few.Hmmm. I got the Dynatrac lift because it’s not too high and is claimed to have great ride and handling. Does it ride badly compared to stock?
To be clear, my lift isn't Mopar. Their LCA's may be a little longer than mine since they do provide more lift.It is amazing Mopar lift almost adding about 3" height, but the LCA is barely longer. That is inviting for troubles. Also the track bar is probably pushed to the side too.
FWIW, I just have a simple 2" Daystar lift. It rides and handles exactly like stock. Aside from the increased height you can't tell it's been changed.. That's exactly what I was looking for, and don't need any increased off-road capability or load capacity or anything else. Stock works just fine for me, but I wanted it a little higher.
Anyway, the slightly longer LCA's (from my photo) kept the caster the same as stock after the 2" lift. I measured it before and after the lift and right on, just as it should be. I would hope Mopar's LCA's are slightly longer than mine so they adjust for the extra lift.
Also, any lift you add will shift the axle due to the change in the track bar angle. Mine shifted 1/8" as a result of a 2" lift. I did a lot of research on the topic, and the general consensus is that longer/adjustable track bars aren't needed until you start getting to 3"+ lifts. I had actually planned on changing mine, but after talking to alignment shops, experienced Jeepers, lift manufacturers, and a lot of online searches it was nearly unanimous saying it's not needed for 2". This was supported by the fact that Mopar doesn't adjust with their kit, and by driving mine after a small lift. If Mopar's kit gives you 3", as I've read it does, I'd change the track bars too.
