Installed Valkyrie Rubicon Hood Vents Today
WilhelmSR
Wilhelm
Maryland
2021 HellaYella JLUR
Cut up pre filter fabric to keep debris out. Used 275f cloth tape so engine heat should be no problem. Cut hood pad. Forgive format on mobile
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
Where does the passenger side vent end up in relation to the battery? Would it expose it to a lot of rain water? That was my main hesitation with this.
I was considering this because my hood solar panel control unit often goes into overtemp mode after the engine is turned off and it's still hot with no fan.
WilhelmSR
WilhelmSR
Wilhelm
Maryland
That's the purpose of the pre filter. I set it up to still use the hood pad to drain down the side as it side. Plus I covered my battery terminals in dialectic grease. You should do that anyways.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
I have the Cascadia one but it's the smaller Rubicon version. How do you know it's in "overtemp mode"?
Also, can you just prop your hood open after you shut it off for a few min?
Reinen
Utah
Red LED in medium speed blink. And by touch. It's obviously hot. Yes, propping your hood open cools it quickly, but do you really want that to be part of your routine?
Themistocles
Virginia
'03 Ram 2500 Cummins / 20 JLURD
I have been considering these for a while now. Have you been tracking engine temperatures during different types of driving? If so would love to hear if this had any impact, up or down.
Thanks
WilhelmSR
WilhelmSR
Wilhelm
Maryland
Thanks
Definitely made a difference. Drove 150 miles non stop the other day. Pre filters stayed no problem, engine/radiator temp needle is lower than ever. Middle of half and tick below it. Love them so far
Dyolfknip74
2021 JLU Rubicon
Ahh, of course, never thought of actually looking at the module. Granted, mine is purely a trickle charger for the shitty battery system.
What does Cascadia say about it doing that?
Reinen
Utah
It shuts off automatically so it doesn't cause any voltage or battery issues. In general it isn't helpful to its lifespan. Or the adhesive sticking it to the air intake as Cascadia suggests.
