Installed Teraflex 1.50-Inch Performance Spacer Lift Kit -- What size falcon shocks should I get for best ride?
BigBruse
Robbie
Va
2019 Jeep rubicon
I just installed the Teraflex 1.50-Inch Performance Spacer Lift Kit on my jeep JLU rubicon. What size falcon shocks should I get for best ride? Should I get the 2-3in lift or 0-1.5 lift shocks?
Marine2146
North Carolina
2023 Grand Wagoneer 3 series, 2022 Rubicon 392
I’m also curious which to get but for the diesel rubicon, it sets about 1” taller than a gas rubicon.
looks like most people are running 0-1.5 on the rubicon.
one person said the 0-1.5 shock is 1” longer than a rubicon shock. https://www.jlwranglerforums.com/forum/threads/1-5-inch-spacer-lift.12882/
BigBruse
Robbie
Va
2019 Jeep rubicon
BuyHold
Tim
Washington
'21 2-Dr Rubi, '23 JTM
@aai @Alanscott1 @UKCATS @rubited19
We are interested in getting some long term evaluations about Teraflex 1.5in ST1 lift and shocks each of you went with. Appears you have all installed this setup a few years ago. We would welcome hearing anything you can say about your experience on the lift, shock choice, or anything else.
GATORB8
CLT NC
21 JLURe
Bump stops will play in to your decision. Looks like the 2-3" 2.1s fronts have a compressed length 2.15" longer than the stock Rubicon shocks. Without extended bump stops, you'll bottom out the shock before the bump stops contact.
GATORB8
CLT NC
21 JLURe
To follow up, looks like the extended length is a significant difference as well. The 2.1 0-1.5s are 24.25 compared to the 2-3s at 27.6. Stock Rub is 23.63, Mopar 2" foxes are 26.25.
Since the 3.1 0-1.5s extend to 26.6, I'd go for the 2-3 (if you're going with 2.1s) with a 2" extended bump stop, unless someone more knowledgeable has better input. I'm not sure if the stock arms have enough flex to take advantage of the additional droop. But this also sets you up in case you decide to increase lift in the future.
aai
aai
somd
'18 JL 2.0 Rubicon : '20 JT 3.6 Overland
same as the day I had installed it, 45k miles ago. Firms up the ride for better handling. Happy with the purchase.
BuyHold
Tim
Washington
You have the 2.1 Falcon 0-1.5" lift shocks, right?
aai
aai
somd
correct, it was a kit at the time. I don't know what's the latest
word302
Oregon
JLU
Falcon shocks and “best ride” are not usually used in the same sentence.
cavguy
Arizona
2020 JLUR
I just installed the Teraflex 1.5" spacer lift on my JLUR as well. I additionally added the following;
2" front and rear bump stops (Mopar lift)
Extended front and rear sway bar links (Mopar lift)
Mopar lift LCA's
Front and rear Bilstein shocks (5100)
I found the Bilstein's ride very smooth and they were definitely priced right, but I need more time to evaluate how this setup works before I recommend anything.
BuyHold
Tim
Washington
Could you provide the part numbers for the Mopar lift extended front and rear sway bar links? How much longer are they than stock ones?
cavguy
Arizona
2020 JLUR
68306982AA
68306981AA
I actually didn't measure them before installing. But they are definitely longer, (and they do not appear to be too long for the lift which is 2" in the front and 1.5" in the rear).
cavguy
Arizona
2020 JLUR
Next, I am going to relocate the rear E-Brake cables below the crossmember with the Rancho RS62136 Emergency Brake Relocation Bracket.
The Teraflex kit has you remove the bracket all together (but they don't say anything about relocating the cables themselves)... I don't like the idea of the cables being unsecured.
