toogq4u2000
Thank you!They probably are referring to set it up into factory computer. By purchasing alarm system to handle the lock actuators you keep system separate from Jeep. I’ve had no issues.
Do you have power windows? I do not have power windows.Thank you!
Sure, but you need to put in wire quick disconnects at the door hinge where the current disconnects are.Can u still take off the doors with power door locks?
What parts did you use to get this done?Thanks RubenZ for the great write up on installing remote mopar power door locks on the 2018 JLU. I have completed all four doors with your help, still trying to locate a tailgate power lock (they are on back order). Today I wired the light flash wire for the remote into the hazard switch on the dash by hooking up a RL44 relay. Hooking the (white) light flash wire to the coil on the relay and the other side of the coil to ground. I used quick splice wire taps on both wires going to the hazard switch and wired each side to the switch portion of the relay. It was easy to do and provides a flash from all hazard lights when locked and two flashes when unlocked.
Thanks because this shop was telling me that I can not work.. Had a alarm system placed in the jeep and he told me I can choose to have the power locks or lose my option of taking off doors..Sure, but you need to put in wire quick disconnects at the door hinge where the current disconnects are.
https://www.amazon.com/MUYI-Waterpr...NDG8FVG4MNZ&psc=1&refRID=TAT7EFYS4NDG8FVG4MNZWhat parts did you use to get this done?
NoCan the door lock module work without the alarm module??
YesWill the part numbers stated in this topic work for the 2019 Sport?
Once the mod is made, will the regular door lock and unlock buttons still work.
Thanks
