Installed New Teraflex 3.5" Lift w/ 37's
Brew211
Brew211
Todd
Peoria, Arizona
2018 JLUR - Manual, Tundra, JL 392 (on order)
Looks awsome! Would you mind please, if you get a chance to measure from the ground to the highest point on the roof. I need to see if this will fit in my garage, but I dont think so :(
Ground to highpoint of hardtop: +/- 78"
Brew211
Brew211
Todd
Peoria, Arizona
@Brew211; Looks awesome! Out of curiosity...have you re-geared and how badly has this affected you MPG?
I have not re-geared as of yet. I can definitely tell the difference, I have not had an opportunity to take it off road yet but its decent on the road and unless its horrible off-road I'll probably keep it w/o gearing.
My Tazer comes in Friday so with the tire size wrong so is my MPG
Brew211
Brew211
Todd
Peoria, Arizona
Thinking about this lift (Sport T/S) paired with the Falcon 3.3 shocks for my Jeep. Mine is Sting Gray otherwise they are the same. Did you upgrade your shocks?
I plan on running 37x13.5 18’s. By the way it looks, could actually do 38’s! Looks good
I went with the Falcons
Brew211
Brew211
Todd
Peoria, Arizona
Looks awesome, is the kit a complete kit or did you have to make other mods to get the kit to fit and work?
Everything was included. The standard shocks were the Falcon 2.1's. I may upgrade later, but the wallet is currently empty.
Tocsholman
Scot
2018 Jeep JL Rubicon
How is the ride quality on the street? Comments? Have you had a chance to go off road yet?
ERIXJLUR
Eric
Studio City CA
2018 Granite Crystal Rubicon 2.0L (ordered on 2/12 received on 9/26)
^ Really good looking Jeep!
rizej
Jared
Denver, CO
Was busy at work today..................
What is the backspacing of those wheels? Would stock Rubicon wheels with 35 or 37s clear or would new wheels also be needed to fully flex
Brew211
Brew211
Todd
Peoria, Arizona
I don't know about stock wheels, these wheels are 17x9.5 with -12mm
chiggerdude
Brian Head
Bloomington
2018 JLUR and a 2010 JK - 2010 JK Sport
So I got a call from my local shop saying that Teraflex sent them one of the first 3.5" lifts as a beta. I got it installed and it is absolutely awesome! True 3.5 inches, with 37's it raised the jeep almost 6". Teraflex really thought everything through and the shop says it is far superior to the Mopar lift. Teraflex is also coming out with a 4.5" lift but I don't see a need for it unless you want to run 40's.
I got the same early released lift at the end of September. There's a couple things that need addressed.
My lift did not come with front or rear track bar extension brackets, Not sure if yours did.
Now.. They sell a bracket separate, but technically it's not the correct front one.
Call TF and they will ship you the front TB bracket that SHOULD have came with that kit.
I'm also ordering the bracket for the rear. At 3.5" it will need it during some flexing and body centering.
TF also told me since I'm using the front LCA geo brackets... my drive-line is fine.
But the rear will need some uppers to correct the geometry. I'll prob go with core4x4.com because TF is slow to the game for adjustable arms.
These were also just released. https://www.quadratec.com/p/terafle...OPMOMjmhC0fDAPF4o-JpK2VMq8eZrb_RoCh6MQAvD_BwE
Perfect for this lift. Allows the removal of those bump shim plates. 1/2" plates are only needed after new bump stops install.
Brew211
Brew211
Todd
Peoria, Arizona
Thank you so much for the heads-up. I'll check it out when I get home today.
Brew211
Brew211
Todd
Peoria, Arizona
It's interesting, mine was installed with the rear track bar extension bracket but not on the front. But mine did come with the teraflex bump stops. I'll call on Monday regarding the front TB bracket. Thanks again for the heads-up
OkieMizzou
Arizona
2018 Granite Crystal JLUR, 2001 Jeep TJ, 2013 Ram 2500 6.7L, 1991 Harley FXLR
Pilot
Thanks for posting all of the info regarding the new measurements. I'm getting the same lift and will also be running 37s. Assuming that you park it in a garage? If so, how is the fit through the garage door opening? Really tight?
Jim Marsh Chrysler Jeep
