EugeneTheJeep
Any throughs on park vs neutral for a DIY lift install? Why do the Mopar Instructions show neutral for an automatic?
Thanks for the reply. Do you mean the axle rotation to connect the new arms and links? Why would locking the wheels from rolling make it harder?It will be easier to get the axle housing into position with the transmission in neutral. With the transmission in park, you may have to rotate the axles & differential, which could be impossible if the parking brake is set also.
Personally, I would just leave the transmission in park with the parking brake off.
Yeah, I don't know what I was thinking, but this part is not accurate. There should be no issues leaving it in park.It will be easier to get the axle housing into position with the transmission in neutral. With the transmission in park, you may have to rotate the axles & differential, which could be impossible if the parking brake is set also.
