Install 2 door Rubicon springs on a 2 door JL S questions
KeithF
Central Va
2021 Wrangler 80th Anniversary
I have been searching the site a few days now and cant find much on this swap.
I have a ‘21 2 door anniversary 2.0 engine with tow package and springs/shocks (and Mopar lift LCA’s) from a ‘21 Rubicon with steel bumper, tow package, hard top and 3.6 etorque. Will this give me the 1.5” lift the 4 door guys get with springs from the 4 door rubicon?
Right now I dont want a large amount of lift, dont have the funds nor am I ready to do that much to my Jeep until I have more miles on it and the money to do it right.
If I end up installing these will I need spacers to get rid of the rear squat?
rts4714
Ryan
Charlotte
2020 JLU Sport S
It varies. But 1.5in seems to be the average. Hard top/steel bumper/tow gives a higher lift than rubi springs without that.
blnewt
New Mexico
Just ask @cosine he knows!
2dr Rubi springs will probably be 1/2" less lift give or take over 4dr springs (from a Rubi w/ the same configuration). I'm just guessing, but Rubi springs from the heaviest 2dr Rubi setup vs. 4dr Rubis springs from the lightest 4dr Rubi setup would probably be very similar in net lift on your 2dr.
Haven't checked this list from @AnnDee4444 in awhile, but maybe some of the 2dr Rubi springs cross over to the 4dr models depending on equipment options.
https://www.jlwranglerforums.com/fo...r-sport-s-question-though.65890/#post-1394774
AnnDee4444
'18 JLR 2.0
So far I haven't found any 4-door springs on 2-doors. That doesn't mean it didn't happen, just that I haven't come across where it did.
My current theory is that there is really only a slight range of spring rates for each trim level, and most of the different part numbers are for different free heights. The spring rate variations are probably just a result of not being able to easily manufacture the exact rate, with a close enough being acceptable. The spring rate targets were probably chosen by total vehicle weight, but I would bet that the un-sprung mass (axles/wheels/tires) was also a factor.
Per this, this, and my guesses:
SpringFront Rate #/in.Rear Rate #/in.
JLU Sport114-121171-174
JLU SaharaSport with taller free height?Sport with taller free height?
JLU Rubicon123-128172-176
Mopar 2" Lift (probably 3.6)131-133180-182
Diesel, 392, 4xemore than Sport, Rubiconmore than Sport, Rubicon
2-Doormore than equivalent JLUless than equivalent JLU?
KeithF
Central Va
These are the springs I have, they came off a 21 rubicon 2 door with steel front bumper, hardtop and tow package. Also had the V6 with e torque.
Can you tell which are left and right by the numbers?
Paul19JLR
Paul
Shelby Twp. MI
2019 JL Rubicon
Both those numbers show rear spring left right. I would assume the taller of the two would be the right to offset the fuel lean.
KeithF
Central Va
I just measured the springs and the higher numerical springs are longer by about 3/8”. I used 2 framing squares to make a crude set of calipers.
KeithF
Central Va
I haven't installed the Rubicon pieces yet, waiting to get more miles on my Jeep first. The Anniversary model is advertised as "heavy duty suspension" so I wrote the spring numbers down that are installed now as original. Dont know if this means anything to you guys, (and I double checked the tags on the front springs). Spring wire diameter's run 13.5 to 14mm on all springs with the variance running the length of the springs.
2door Anniversary hard top, tow package, 2.0 turbo.
LF 6825 0236AD
RF 6825 0228AD
LR 6824 9109AA
RR 6824 9110AA
2 door Rubicon take-offs: Hard top, tow package, steel bumpers 3.6 etorque
LF 6825 0229AD
RF 6825 0230AD
LR 6824 9111AA
RR 6824 9113AA
I only want 1.5 to 2.0" lift, do you think this will get me there? I know your charts dont have much info on the 2 door.
orange2dr
2019 JL Sport, 2 Door, 3.6 L, 6-Speed Manual
Currently have my eye on a similar set of springs (0229/0230,9113/9114) I'm hoping can help eliminate some of the squat I get when loaded up for car camping without lifting too much. Have a 2 door Sport with soft top and tow package (0228/0228,9109/9110).
Did you end up going through with the install? If so, were you happy with the results?
entropy
Foothills of the San Gabriels
Jeep Wrangler Sport S JL 2-D
Professional dancer/male stripper
I got a bit over 2 inches front and 2 inches rear on my 2n door sport after i installed bumper,winch and skid plates it ended up being 2inches up front,
. Springs came from a 2 door rubicon fully loaded. I think it had a 2.0 tho and I have the 3.6. i dont remember. However my springs afe 31/32 and 14/15.
I had to buy longer shocks, the rubi shocks didnt fit. Bizarre since my springs didnt even come from a 4 door lol. I guess i got "lucky"
