Input Requested: Fox Shocks on Rubicon
Brock9281
Robbie
Alpharetta GA
2021 Rubicon Unlimited
I’m looking to add a Rubicon Express economy kit to my Rubicon. Was told the 2” kit will add 2” to front and a little less in rear to level using shock spacers.
For extra was told I could have Fox Shocks 2.0 added.
Question is how different will the Fox Shocks make JLUR ride and drive? This is being added for 1) a little extra height 2) run 35s with proportionate wheel well look. I’m wanting to keep the ride/drive as pleasant as possible as this is my daily driver and will be taken on road trips to beach, etc.
Thanks!
Themistocles
Virginia
'03 Ram 2500 Cummins / 20 JLURD
First shocks are most valuable when they are valved to pair with your springs/vehicle usage & weight. I would ask whether these are off-the shelf Fox 2.0s or if Rubicon Express has specifically had them valved to match their lift (which would mean OEM springs because the lift is just a spacer lift.) I suspect the answer here is they are just off the shelf units...which does decrease their value a bit. Now with that said Fox makes really great shocks (have four Fox 2.5" DSC shocks from Accutune sitting in the back of my Jeep about ready to be installed).
To me the answer has to come from what you want and how you think the Jeep works currently. You say you want to "keep" the ride as pleasant as possible. I take that to mean you like the stock ride and don't want to lose that comfortable ride as you add stuff. You also lay out a usage model for your vehicle that is pretty mild. In this case, I am not sure the benefit of a set of Fox shocks would be worth the cost (unless you have money to spend...in which case why not?) The kits comes with shock extensions so you can re-use your OEM shocks. This will keep you as close as possible to your OEM ride. If you like it, why throw money at a problem that doesn't exist?
My 2 cents...if you are looking for someplace to spend some money that will have the biggest bang for the buck in your suspension...find some adjustable length lower control arms and put those on instead of replacing your shocks. I would not replace OEM shocks unless one or more of the following were true.
1. I did not like the OEM ride and wanted to change it​
2. I was going to use the vehicle in a way that exceeded the capabilities of the OEM shock​
3. I was going to change the geometry of the suspension in such a way that the OEM shocks no longer fit the suspension​
Brock9281
Brock9281
Robbie
Alpharetta GA
Great insight, much appreciated as this is my first Jeep!
I have a 2021 Rubicon 4 door. Not gonna lie and say this will be a “mall crawler” so the tires and stance is really for looks.
Drive now is good although I could stand for the steering to be a lighter tighter although I’m sure that expected with a Jeep.
For the Fox Shocks, would imagine they are off the shelf. Work being performed will be either at Southern Off-road Specialist or Fortec in the Roswell/Cumming area.
Themistocles
Virginia
When I first started club racing sport bikes I was told be our local track pro, when I asked a similar question about what I should do to my CBR, to forget the engine and focus on suspension. The engine was more powerful than I could use as is, and if I couldn't safely put the power to the ground and keep traction, then all more power would do would be to kill me faster. I listened to that advice, put on the best steering damper made and Ohlins shocks front and rear. I then upgraded brakes and tires. I then worked on rider geometry. After all that was done and I felt like there were times I was starting to ask something of the engine that it couldn't give, I started to work on HP. Then an old lady who could barely see over the wheel turned left in front of me going into a mall and destroyed my bike...but the story holds. Do the important stuff first, not the flashy stuff.
In the Wrangler everyone wants to go high and put on big tires...to me the first thing is steering. Wrangler steering sucks...make sure you have the aluminum steering box replaced. Put on something like the Steer Smarts sector shaft brace. Throw a good steering stabilizer on (the Fox ATS is great), maybe replace your track bar and tie rod. When you do raise it and put on bigger tires don't forget to correct your geometry, extend your brake lines, consider your driveshaft, etc.
So in short...instead of dumping money into the new shocks...spend it on your steering. Save shocks for another day...at least that is how I would do it knowing what I know now.
LOBBS
Kyle
Independence, MO
JLR
Quality Manager in Automotive Aftermarket
In the Wrangler everyone wants to go high and put on big tires...to me the first thing is steering. Wrangler steering sucks...make sure you have the aluminum steering box replaced. Put on something like the Steer Smarts sector shaft brace. Throw a good steering stabilizer on (the Fox ATS is great), maybe replace your track bar. When you do raise it and put on bigger tires don't forget to correct your geometry, extend your brake lines, consider your driveshaft, etc.
Along these same lines, I grew up with hot rods and muscle cars. Took an interest in 4x4s much later. Re-gear to the tire size you plan on running. Even 4.10s on the Rubicon are barely adequate for the stock 33s. People that slap bigger, heavier wheels and tires on and say they don't need to re-gear are lying to themselves because it isn't a flashy mod. It is expensive tho. But it's not seen as optional really anywhere but in the 4x4 world for some reason. I can't wait for my tires and rear gears to come off backorder so I can get them installed. Then I'll worry about adding more lift.
dpike
New Jersey
'20 JLUR 3.6
fox 2.0s on my Clayton 2.5" lift are much more plush than the OE rubicon suspension.
JoeBelt
2018 Wrangler Unlimited Sahara
An old thread but I’d like your feedback on the Fox 2.5s. I have a wrangler rubicon unlimited with the stock red shocks. Rides like a dump truck. How about a review in 300 words or less? ;) Appreciate it!
Themistocles
Virginia
Will try. First, I will point you at my build thread ( Diesel Build - 2020 Sting-Gray JLURD | Jeep Wrangler Forums (JL / JLU) - Rubicon, Sahara, Sport, 4xe, 392 - JLwranglerforums.com ) This provides the status of where I am now with the build...which influences my suspension geometry, weight and balance, and usage model.
Thoughts on Accutune Fox 2.5 DSC shocks: Bottomline absolutely love them. I say that for many reasons. First the adjustability of the shock allows me to set-up the ride dynamics that I like. My other vehicle is 2003 Ram 2500 CTD...which rides stiff. I also drive moderately aggressively...not crazy, but I generally have places to go and not unlimited time to get there. What I have found is for on road I like a fairly soft setting on high-speed compression, and a fairly stiff setting on low-speed compression. That soaks up the bumps while effectively controlling body role. Same general concept for all different terrain and usage. Takes a little time to dial in, but the adjustability is like having about 10 different shocks on hand. Second, for me I like a little bit of overkill. I like having the margin in my shocks, so I know I am not pushing them to their max. I know the 2.5 is more shock than a jeep really needs, but that is what gives me a margin of safety and means I am not pushing the shock up to its limits. Third the Fox (2.0 and 2.5) Remote Res shocks were the only ones that matched my compressed and extended measurements. I didn't want to add a bunch of bump stop or have to put in a limiting strap because a had shock that was too long collapsed or to short extended. These match nearly perfectly.
So overall, would I spend the money on these again...yes, yes, and yes...but I wouldn't wait nearly 2-years to do it. These are the shocks the JLUR needs.
JoeBelt
I appreciate the feedback. So basically it’s time to contact Accutune. I have a bone stock Rubicon diesel, but I’m about to install 35s and a winch to have some fun. Hopefully it’ll be a bit more compliant with the adjustables day-to-day.
I have a Porsche 993 with KW V3 adjustables. Handles like it’s on rails and the ride is almost plush. Maybe I’m getting old. Damn…
Themistocles
Virginia
Sounds great. And agree the right shock makes all the difference. I always put Ohlins in my sport bikes as soon as I got them home.
One comment for the shocks. I went with the 4.5 - 6 inch version with a 2.5 inch Clayton suspension...after doing all the measurements. I would recommend measuring at fully compressed and fully extended before ordering the shocks.
AccuTunedJL
El Cajon, CA
2018 Jeep JL Rubicon
And we have a new article that goes over measuring for new shocks and why its important ;)
https://accutuneoffroad.com/how-to-measure-for-jeep-shocks/
COJeeper
Severance, CO
'22 JLUR, '23 Donkey because gas is too expensive
If I'm understanding this correctly, your Jeep is going to be a mall crawler? If so, why not just run with some spacers to add the 35s? Cheaper and easier to install.
How's the weather in GA? I'm flying into Atlanta on Sunday and spending the week in Adairsville.
Whaler27
Alex
Oregon
Saving the world :-)
The Fox shocks that are paired with the 2" MOPAR lift (which is really closer to 2.5"+) are a good match to most driving conditions. They are comfortable, they manage the additional travel well, and they transition well from highway to off-road to highway.
A lift changes the suspension geometry, obviously, so there's more inclination to sway fore and aft and side to side in response to control inputs. So, for example, when you mash the accelerator you feel more of a backward rocking motion. That rocking is gentle with the Foxes, but it becomes more noticeable and more profound as weight is added to the jeep.
I'm building an overland Jeep. Winch, big tires, suspension, rooftop tent, heavy automated steps, fridge, and other additions have added close to 800 pounds. The additional weight made the Fox ride much too spongy, so I removed my Fox shocks after less than 7500 miles. For me, the solution was the Falcon SP2 3.5 E-adjust shocks. They're infinitely adjustable and, once you've defined your preferred ranges, you can manage the settings with the flip of a rocker switch inside the jeep.
I see a lot of advocacy for steering stabilizers as though they improve steering or fix problems like "death wobble". They don't. Stabilizers can partially mute some problems, but they don't fix any. If you lift, adjustable control arms and a SteerSmarts "Yeti" are worth doing at the time of the lift. After that your jeep should steer and drive like butter. Once you've achieved the balance/drive/steering you want, a good stabilizer is a sensible addition, as it will soften abrupt jolts -- for you and your suspension components.
