Increase Clearance Options
Sean K.
Sean
AZ
JLUR, TJ, 4Runner, Cummins tow rig, 2 Tube Frame Buggies, Lotus SC Elise, Mazda 3, RAV4 Hybrid
I'm at 12.5" to the bottom of the front diff. Couldn't accurately measure the rear b/c there's a few layers of cardboard on the floor and only one tire is parked on it, but it was reading 12.25" with the cardboard under it...so it's probably real close to the front...maybe just a hair higher due to the decreased weight bias to the rear of the vehicle affecting how much the tire sidewall squats.
TA1ton
Travis
Tyler, TX
2018 Jeep Wrangler JL Sport S
Civil Engineer
@UNC Rubicon, @Sean K.; another way to get clearance (in both cases) would be portal axels! I’ve seen a couple of jeeps with portals...but no JLs that I can think of. Also...I do realize that portals are probably outside the realm of reality for OP and most people for that matter.
Sean K.
Sean
AZ
Portals have some pretty big drawbacks in terms of ride height though....you generally have to move the axles out from underneath the vehicle (especially the engine, be it fore or aft)...and that would also necessitate full hydro steering if you have a front engine configuration.
In short, your CoG is going to go through the roof with portals unless you stretch the already very long wheelbase on an Unlimited to push at the least the front end out from under the vehicle and then you also have to go to a balanced full hydro system with a load reactive orbital (and the accompanying, obligatory upgrades to the axle knuckle and steering arms) if you want any semblance of a normal road driving/handling experience. And that doesn't even take into account the oddities of on-road driving a portal axle and its geared reduction boxes as well as the link geometry issues caused by having the axle tubes located so high in relation to the vehicle's roll axis.
Then there's the price of all of the above. U13/1400 Mogs are the obvious choice (400/406 series aren't really a good choice from a reduction box standpoint) or custom hybrid Volvos or the like....you're talking easily $20K in axles alone...not to mention custom fab, $3K in steering, new wheels, etc.
Might make sense on a buggy....not so much on a full bodied JLUR.
Sean K.
Sean
AZ
Roky
Roky
North Central Florida
Thanks for measuring, that’s 3/8” difference in a true 37, I’m assuming m/t tire?, and a kinda hybrid m/t, / a/t tire. I know it’s not an exact science but I was just curious how much difference there was between the two.
Sean K.
Sean
AZ
Yeah, 3/8" in loaded radius. Mine are PitBull Radial Rockers...I'd assume they're classified as an m/t.
TA1ton
Travis
Tyler, TX
Civil Engineer
@Sean K.; I completely agree...those are the reasons I said they probably aren’t in the realm of reality for most people...they are awesome on a purpose built rig...but a daily driven rig would not be a candidate for them.
Sean K.
Sean
AZ
No, I noticed your original caveat.
I was just listing the drawbacks for those that might not know.
I'd disagree that they're all that "awesome" on a purpose built rig either. If they were that great you'd see them on every competition rockcrawler and Ultra4 car and you don't. To each their own though.
Done Right LED
