I'm Not OCD, But This Bugs Me
Gummiente62
The Great White North
gummiente62.blogspot.com
18 JL Sport, 97 C5 Corvette, 03 HD FXD
After removing the stock rear bumper ( there was way more plastic than steel) and installing an aftermarket unit, there's a noticeable bit of bodywork edge just hanging out in the open now. I've sprayed some rustproofing oil into the gap, but would like to find a way to cover it up for aesthetic reasons. Was thinking maybe a section of u-channel weatherstripping, but not sure if that would work. Anyone have any ideas?
Gummiente62
Gummiente62
Will
Will
Georgia
'18 JLUR
You can pick up matte black outdoor vinyl from a local sign supply shop. My wife keeps some on hand for her Cricut hobby. I am going to use some to cover up the spot you mentioned between the fender and the bumper. It stands out pretty bad on white JLs.
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
I actually cut some of that off (for 37 up-travel), then used some JB weld to fill it, then sand, then color-matched it. Turned out pretty good. I dont have a pic handy (sorry), but i know i have it in my build thread somewhere.
calemasters
Allen
Springfield, Mo.
2021 Rubicon Unlimited, & Escalade
Retired Mechanical Engineer
Fill the gap with white silicone sealant/adhesive.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Wandering Vaquero
Do no put acid adhesion silicone caulking on aluminim. It will corrode it. Make sure that it’s neutral adhesion.
Carolina Jeeper
Rollie
North Carolina
2019 Mojito! Jeep Wrangler Unlimited Rubicon
Electronics Technician at R. J. Reynolds
You're not alone. When I was looking for an aftermarket rear bumper I knew I would not like this area with a shorty bumper. So I got a full width bumper from LOD that covers it pretty well.
I'm not cutting off this area and putting cheap crap in to fill a hole I made. In my opinion it should be done correctly and welded closed. Yes I know Jeeps come with seam sealer, but it's not filling a gaping hole that's being blasted by rain water and mud.
JackA
Jack
Washington State
2021 JL Rubicon; Nacho
If you are not into cutting factory body panels you could hide this pretty successfully with a can of black undercoating. It is pretty amazing how black blends with the other under body parts then is not noticed. Check the body pinch seam (behind the skid rail) it was very noticeable until undercoated.
Jeep Wrangler JL I'm Not OCD, But This Bugs Me Pinch 1
