If you're going off-road, protect that front differential from damage/leaking!
Brian0128
Annapolis, MD
2019 JLUR, 2018 Toyota TRD PRO
Engineer
I really like the build quality of the Next Venture Motorsports. I hope they release a Front Diff Skid soon.
ATXMTB
Ben
Austin
Ocean Blue JLU Sport S, Red Grand Cherokee Trailhawk
wolfdog
George
Southern Massachusetts
2006 Yamaha FJR1300, 2021 JTO, 2018 JLU Sahara
Maritime Artisan, Mayflower II
That's not a solution, that's a cop out.
Not at all, that's a joke!
Of course this is a stupid place for the drain, bangs like that can happen anywhere with serious off road travels! I do believe however for serious rock crawling/climbing, one should have a dedicated vehicle and with that all things would be protected!
Go Jeep!!!
johnparjr
New Caney, TX
2024 Jeep Wrangler Sahara 4xe
Wish someone would make a slider for the rear dif for my 2018 Sahara JL Rancho doesn’t and neither does metalcloak. Rancho does make the front but not the rear
TheEddie
Eddie
Colorado Springs
2021 JLUR 4XE
It would have been fine if they just protected the bolt better/created a shoulder/recessed the drain plug. Maybe a shorter plug could be designed that prevents direct rock contact.
Jeepin_Donnie
Donnie
Northern VA
18 JLUR, 23 Wildtrak Bronco w/Sasquatch package
Benefits Manager
Rancho makes one for the rear too. (Do they not make one for the Sahara axle?) I went with the MetalCloak one though.
johnparjr
New Caney, TX
So the Sahara and sport both have the Dana M200 axle which according to Rancho is an odd size so right now nobody makes one for the rear
D60
CO
JL
I'm struggling to see EXACTLY the problem? In Post #1 the plug looks recessed as it is .
I mean sure there's rock rash but what's the complaint? That the plug was loose? Isn't it easier to just check it occasionally and carry a spare pipe plug? I'm guessing this is NPT?
I mean I'm not in favor of dumping gear oil on the trail but the skidplate solutions look to eat up valuable ground clearance (and like they came from the AutoZone "tuner" aisle) and IME when 'crawling even 1/4" matters
What's the worst anyone has seen here? Anything beyond a loose plug?
Jeepin_Donnie
Donnie
Northern VA
Benefits Manager
That's unfortunate.
TroyBoy
Troy
Vancouver Island, Canada
I was wondering if it would be possible to weld up the drain hole?
Jeepin_Donnie
Donnie
Northern VA
Benefits Manager
I believe it was Eddie from [Banned Site] that damaged the plug almost beyond repair. It was leaking and he couldn't tighten or loosen the bolt due to the rock rash. That in their opinion and mine is the reason the slider is worth it. If it is too damaged to remove the plug, that extra plug you suggest isn't going to do you any good. I have the Rancho diff slider on my rig, I go wheeling often and the lost clearance hasn't been an issue for me. The slider does it's job well. Again, this is my opinion. The slider is a little pricey at a cost of approximately $150 but it's worth my piece of mind.
Andy2434
Andy
Las Vegas/San Francisco
'19 Billet JLUR, ‘20 Mustang GT/Prem/6MT/PP1
Retired/Leisure
Damaging the drain plug is only one element of concern. Damaging the diff covers is another real concern for many.
D60
CO
JL
Short answer: yes
Longer answer: successfully welding cast is kind of a hassle. I agree that tacking a plug in place would be best. To fully weld it you'd want to pre-heat, post-heat and use a high nickel rod. I'd hate to sink that much heat into an expensive, new housing (that's just me). I've done it with junkyard 14 bolts without worry :)
