If you're going off-road, protect that front differential from damage/leaking!
Tritonman
Keith
Upstate NY
2018 Rubicon JLU
ITS Duty Manager
Did you have any trouble getting the glide plate to line up to the diff correctly during install? Mine doesn’t line up right. I have double checked and it’s the right model for my Jeep.
Mine went in good, but i have heard issues where one of the holes has some weld left in it and you have to dremel some of it out to fit it correctly.
Tritonman
Keith
Upstate NY
2018 Rubicon JLU
ITS Duty Manager
Brian0128
Annapolis, MD
2019 JLUR, 2018 Toyota TRD PRO
Engineer
I really like the build quality of the Next Venture Motorsports. I hope they release a Front Diff Skid soon.
ATXMTB
Ben
Austin
Ocean Blue JLU Sport S, Red Grand Cherokee Trailhawk
baron95
USA-CT
2016 JKUR Hard Rock
these items are easy fixes, aftermarket takes care of it.
No they are not.
There is NO WAY to fix the dumb drain plug location without losing a lot of ground clearance or replacing the axle housing.
On the JK, all you need is a $100 Poison Spider diff cover and you are protected with no loss of ground clearance.
P.S. Changing the diff fluid by removing the cover is still the best way. Gives you a chance to inspect the gears, lockers, everything, before bolting the cover back on.
wolfdog
George
Southern Massachusetts
2006 Yamaha FJR1300, 2015 Cherokee TH, 2018 JLU Sahara
Maritime Artisan, Mayflower II
That's not a solution, that's a cop out.
Not at all, that's a joke!
Of course this is a stupid place for the drain, bangs like that can happen anywhere with serious off road travels! I do believe however for serious rock crawling/climbing, one should have a dedicated vehicle and with that all things would be protected!
Go Jeep!!!
johnparjr
Roseville
2018 Sahara unlimited JL
Wish someone would make a slider for the rear dif for my 2018 Sahara JL Rancho doesn’t and neither does metalcloak. Rancho does make the front but not the rear
TheEddie
Eddie
Chicago
2019 JLUR
It would have been fine if they just protected the bolt better/created a shoulder/recessed the drain plug. Maybe a shorter plug could be designed that prevents direct rock contact.
Jeepin_Donnie
Donnie
Northern VA
Rancho makes one for the rear too. (Do they not make one for the Sahara axle?) I went with the MetalCloak one though.
Sean K.
Sean
AZ
JLUR, TJ, 4Runner, Cummins tow rig, 2 Tube Frame Buggies, Lotus SC Elise, Mazda 3, RAV4 Hybrid
No they are not.
Uh...Post #15?
johnparjr
Roseville
So the Sahara and sport both have the Dana M200 axle which according to Rancho is an odd size so right now nobody makes one for the rear
D60
CO
JL
I'm struggling to see EXACTLY the problem? In Post #1 the plug looks recessed as it is .
I mean sure there's rock rash but what's the complaint? That the plug was loose? Isn't it easier to just check it occasionally and carry a spare pipe plug? I'm guessing this is NPT?
I mean I'm not in favor of dumping gear oil on the trail but the skidplate solutions look to eat up valuable ground clearance (and like they came from the AutoZone "tuner" aisle) and IME when 'crawling even 1/4" matters
What's the worst anyone has seen here? Anything beyond a loose plug?
Jeepin_Donnie
Donnie
Northern VA
That's unfortunate.
TroyBoy
Troy
Parksville
I was wondering if it would be possible to weld up the drain hole?
