jl73660
- Todd
- Oct 23, 2018
- Fairfax, VA
- Moving on up .....
I vote 5.7 Hemi !
Not really any more complex than anything else with an electric motor. The 2.0 is a good engine, give it a try.Reliability of the Italian engine + new complex Etorque mild hybrid = SCARY
What reliability issues have you seen with the 2.0, which has been in use in slightly different trim in other vehicles for a while now? The etorque system is not complex, it's just a battery, a motor, cooling lines, and wire. There's plenty of that already in your Jeep, aside from the BSG, which is nothing but an electric motor.Reliability of the Italian engine + new complex Etorque mild hybrid = SCARY
Looks like the 2.0 isn't in a number of vehicles not in question here either.... Relevance?Looks like the Gladiator will not get the 2.0 as an option.
If its anything like the Pacifica Hybrid, it should be a good setup. I'm just waiting to see how it actually turns out before I make any opinions on it.I will say this... I'm pretty resolute in my desire to get a plug-in hybrid Wrangler... BUT... based on this poll and how low the "popularity" is I'm starting to wonder if the resale value will take a disproportionate larger hit if the core Wrangler community isn't interested in them. I've glanced at the resale of several other hybrids and they generally seem to be worth more than their standard gas counterpart so maybe it won't be an issue.
Don't make any decisions in your life based on a poll on this forum.I will say this... I'm pretty resolute in my desire to get a plug-in hybrid Wrangler... BUT... based on this poll and how low the "popularity" is I'm starting to wonder if the resale value will take a disproportionate larger hit if the core Wrangler community isn't interested in them. I've glanced at the resale of several other hybrids and they generally seem to be worth more than their standard gas counterpart so maybe it won't be an issue.
Easy there little fella.Looks like the 2.0 isn't in a number of vehicles not in question here either.... Relevance?
Exactly ... MIGHT be great but I don't want to pay for the privilege of being Jeeps guinea pig.Reliability of the Italian engine + new complex Etorque mild hybrid = SCARY
That's a bit of a misquote. FCA stated the v6 was capable of the higher heat load required when towing 7600lbs. It has nothing to do with the 2.0 having the 'Schlitz', as you put it - it's verifiable better on a dyno that is has more torque across most of the powerband (lower redline). They likely did not design the setup to endure extended periods of high heat as it hasn't been put into a towing vehicle yet, unlike the 3.6. Nobody is going to pull 7600 w/ a JL up steep grades, so that's a moot point. The powerband on the 2.0 is definitely better for a daily driver, and I would argue an off-road vehicle. Let's not mix apples and oranges; towing is not the same as daily driving or off-roading.Easy there little fella.
I mention it because Jeep doesn’t think it’s got enough Schlitz for the Gladiator. Which is really the same damn platform. That tells me all I need to know as consumer.
For those deciding which engine to choose, this effects them. Less numbers of these 2.0’s in the field means more expensive repair parts and lots of other things for the future owners. Lots to consider.
