Vinman
- Vince
- Oct 19, 2020
- Calgary, Alberta
- 2021 JLU Rubicon
You win
You win
Is that the eTorque skid on yours? I have the MC full underbelly system and their eTorque skid comes in contact with my rear drive shaft. They had the only kit available for the eTorque when I purchased it. It is HEAVY and I may swap it out.Artec claims the gas tank, tranny and oil pan skids only weigh 10 lbs more than the stock steel skids (which are removed) then another 5 lbs for the etorque battery (stock etorque skid is retained)
Where can I get that option for my Jeep? I have the same color JLUR and so it would go really nice with mine as well.
Yeah, that is the etorque skid. It bolts directly under the factory skid using nuserts.Is that the eTorque skid on yours? I have the MC full underbelly system and their eTorque skid comes in contact with my rear drive shaft. They had the only kit available for the eTorque when I purchased it. It is HEAVY and I may swap it out.
Because it’d cost $2000 more and a lot of Jeep owners will never see the underside, much less drag it on anything. They wouldn’t want to pay for it. Rightly so. It’s mostly for people who go in the rocks.Why don't they come this way from the factory?
You re-use the factory piece that supports the cooling lines to the battery. If you zoom in on that pic you can see it.Do you have the Etorque motor, it kind of looks like you do with that driver side rear skid plate.
Does that manufacture have a bracket to hold up the cables on the front of the 48 volt battery?
it'd be the most expensive option. and no warranty.Where can I get that option for my Jeep? I have the same color JLUR and so it would go really nice with mine as well.
Yeah tell that to my exhaust pipeThe skid plates look very nice. Great job.
I saw a video with a Jeep engineer and he was asked about additional skid plates. He defended the production JL by saying:
1.) Additional skid plates are not necessary as the production Jeep has all of the critical parts protected with the factory skid plates.
2.) Addition skid plates add extra mass and affect fuel economy and GVWR.
3.) Addition skid plates affect the heat dissipation of the engine, transmission, transfer case, exhaust, ect.
I wheel, but I don't do anything crazy. I decided not to add any additional skid plates and see what happens. If something gets damaged, I will then do whatever I need to do to prevent reoccurance. So far, so good, with just the production skids.
Cost to value ratio. Those who would really get value out of this are in the minority. Most wrangler buyers never take it off road. Couple buddies of mine have wranglers and they’re appalled that I do… their wrangler is too precious for that!Why don't they come this way from the factory?
I’ve wheeled monthly at Raush creek and AOAA in PA which are both rock terrain off-road parks. Only thing I’ve done is change my diff covers to ARB. I’m still using the stock skid plates and have had no issues in the 2 years I’ve had my JLU. It’s all about the line you choose. I have a ton of scrapes and small dents on the skids but nothing I wouldn’t expect playing on rocks.Yeah tell that to my exhaust pipe
well I dont know about PA never wheeled there before. but here out west if you are doing difficult trails it is just a matter of time before you hurt something. The stock skid system is great. but the crossmember gets hang on rocks and the exhaust pipe is way too exposed in certain areas that take hits. no matter if you pick the right line or not. nothing guarantees you that you wont lose traction and fall of your line and thats all it takes.I’ve wheeled monthly at Raush creek and AOAA in PA which are both rock terrain off-road parks. Only thing I’ve done is change my diff covers to ARB. I’m still using the stock skid plates and have had no issues in the 2 years I’ve had my JLU. It’s all about the line you choose. I have a ton of scrapes and small dents on the skids but nothing I wouldn’t expect playing on rocks.
because that would add $100 to the cost od the vehicle.Why don't they come this way from the factory?
$Why don't they come this way from the factory?
