If I change to a different tyre, how do I determine the correct tyre pressure?
Joe98
Sydney
2019, 2 door Sport S, Mojito!
I have a Sport S. It came will all terrain tyres and performs well on road and off road. The placard on the Jeep says that the correct tyre pressure is 36psi
Scott.B
Alaska
2022 JLURD
I believe the new tire will have manufactures recommended pressure. But should not change much unless going with larger tires.
Joe98
Joe98
Sydney
My plan is to choose a tyre with almost exactly the same circumference as the stock tyre.
GATORB8
CLT NC
21 JLURe
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
How did you determine tire pressures up until this point in your life?
Turaven
'23 Wrangler Sport 4-door 6MT
The door placard refers to recommended pressure for ideal performance and comfort for the stock tires. If you change that it goes out the window.
Since you're choosing a very similar tire, the manufacturer recommended pressure is probably still good. You can use that and adjust as needed. If your ride is too firm lower the pressure a bit. If your tires are wearing unevenly raise/lower pressure as needed. If fuel economy is bad you can raise the pressure. Just don't go above the max pressure listed on the tire and don't go so low that you'll debead the tire.
sailscall
Buffalo, NY
2021 2dr Sport 6MT
I kind of like this thread, members of the Commonwealth getting lippy with each other. 😂
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
A chalk test will determine the best tire pressure.
Superchips TrailDash 3
