mortimer
Thought I'd share, I have an Icom ID-4100a, and found that it tucks up perfectly on the driver's side behind the OBD port. The head unit for this radio also fits perfectly in front of the gear shifter. After using a cat5 extension cable, the mic sits perfectly near the e-brake with the wire into the console hole for the ebrake (hidden almost completely when not in use).
I was thinking of wiring the audio from the Icom into an aux input for the 8.4 UConnect, but there’s no need. Audio output is plenty loud from the Icom itself without any sort of extension speaker!
The head unit fit nicely in front of the shifter.
The mic tucks nicely next to the e-brake with a cat5 extension cable back to the radio.
Used the ZROADZ Lower A-Pillar Light Mount for the Larsen dual band antenna.
