- Dusty
- Nov 15, 2020
- California
- Website
- iconvehicledynamics.com
- 2015 JKUR
Here are some pics of our JL in Moab. These wheels are 17X8.5 Rebound Pros, 5 on 5 BP with -6mm offset (4.5" backspacing). The part number in bronze is 21817857345BR (Click Here to go to this wheel on our website). The tires are BFG KM3's, 37X12.50R17LT.Assuming the shop JL is a Rubicon, can you post some photos that show the stance that these wheels give the Jeep? All the back spacing talk is hard to visualize and it’s just a lot easier with a photo.
What psi are you running off-road with these wheels??
thanks
I wasn't there when these were shot but just looking at the photos it looks like around 15 PSI. But you can run whatever pressure you want, depending on your needs. If you're just airing down for comfort on bumpy roads, 20 might do it. For maximum traction in the rocks you might go all the way down to 10. For flotation in the sand dunes you might go even lower. The Rebound Pro's pins will help keep the bead seated at any of these pressures but you also need to be mindful of sidewall pinch the lower you go.
