DTS
Peak Sponsor (Level 2)
Dusty
iconvehicledynamics.com
2015 JKUR
Introducing Rebound PRO wheels with INNERLOCK Technology, from ICON Alloys!
Any hardcore off-road enthusiast knows the numerous benefits that lower tire pressures offer such as improved ride quality and a larger contact patch for increased traction. However, low pressures also increase the risk of de-beading the tire during extreme side loads or aggressive driving. While traditional beadlock wheels address this issue by clamping the tire’s bead, they also need frequent maintenance, require specialty tools/parts, increase rotational mass, and are NOT legal for on-road use.
The ICON Alloys Rebound PRO with patented INNERLOCK Technology offers the best of both worlds by using a robust bead retention system to keep the tire bead secured to the wheel while also being fully DOT compliant. This provides confidence in knowing that your wheels are prepared to tackle whatever situation you encounter - on or off the beaten path. InnerLock is ready for any type of terrain and every single adventure.
What Is InnerLock Technology?
Patented InnerLock technology (U.S. Patent No. 11,090,976) is an all-new way of capturing the tire bead and retaining it onto the wheel. InnerLock uses a series of O-ring sealed, hardened alloy pins that are inserted radially on the inner side of the tire bead to create a barrier that prevents the tire from unseating during extreme side loads. Additionally, InnerLock wheels are lightweight, strong, don’t require bolt retorquing, and are DOT compliant for the ultimate blend of on-road safety and off-road performance.
Used. Abused. Lab Approved.
During an accelerated R&D process ICON engineers subjected the Rebound PRO to thousands of miles of real-world abuse throughout harsh and unforgiving environments. After on-vehicle testing was concluded, the Rebound PRO was sent to an independent contractor for precise lab testing, specifically the FMVSS No.139 Tire Bead Unseat Resistance Test (modified to 10 psi). Results from multiple tests validated the effectiveness of ICON’s InnerLock technology by exceeding the mechanical limits of the machine (over 7600lbs load) without ever de-beading the tire.
Staying true to the ICON Alloys approach, the Rebound PRO has been engineered to maximize caliper clearance and optimize wheel position for un-hindered suspension travel and steering function. Backspace and wheel offset dimensions have been strategically developed to reduce scrub radius, improving all-around handling and ride quality. The Rebound PRO has also been strength tested to yield a 3,200lb load rating - making it one of the strongest wheel options on the market. With build features such as these, it's clear that a set of ICON Alloys wheels is the perfect complement to any truck, Jeep, or SUV.
KEY FEATURES
  • Engineered for DOT compliance
  • Patented InnerLock technology (U.S. Patent No. 11,090,976) provides the ultimate blend of on-road safety and off-road performance, ideal for the “weekend warrior”
  • Bead retention system features alloy pins that are removable, reusable, and replaceable
  • Hardened bead retention pins utilize SAE J1926 O-ring seals and are constructed from high strength alloy that is thermochemically treated for extreme corrosion resistance
  • Quick, easy, and safe tire installation and removal
  • Strategically placed hardware for maximum protection from trail damage
  • Compatible with a wide variety of tires without the need for any shims or special tools
  • Application-specific dimensions optimize vehicle dynamics and tire clearance
  • Reduced unsprung weight and rotating mass (compared to a traditional beadlock) improves handling characteristics and vehicle dynamics
  • Aluminum alloy construction provides high-strength properties that are well suited for off-road use
  • Weighs 28 lbs fully assembled
  • Super strong 3200 lbs load rating
ICON Alloys Rebound Pro wheels are available in Bronze, Titanium or Satin Black, directly from ICON or through any of our Authorized Dealers.
Will
Will
Dacula, GA
'18 JLUR
Impressive. Way to innovative. Great graphics in your video as well.
JeepVT
VT
2021 JLURD
I love my rebounds and would have gone with these a year ago if they were out.....looks a great solution for peolpe who want lower pressures but not the weight penalty or complexity of traditional beadlocks
rayzjeep
Ray
Melbourne, FL
2019 Jeep Wrangler Rubicon Unlimited
Aerospace Engineer
When will you get DOT compliance?
rayzjeep
Ray
Melbourne, FL
Aerospace Engineer
Sweet! I really like that you're giving diehard beadlock guys another option to keep the tire on.
SalC
Sal
Las Vegas
2021 Rubicon
Dumb question, I've never had bead locks before. What keeps the inner bead from getting de-beaded? I really like Icon's design, and would love to run these.
DTS
DTS
Dusty
2015 JKUR
Most beadlocks only lock the outer bead. In most off-road situations its the outer wall of the tire that usually gets pushed and pinched. While it's possible to de-bead the inner, it's very rare.
Vanburi
North Texas
2019 'Mojito' JLR
Nothing, that would require a double beadlock which is rare except for extreme sport(baja, king of hammers).
sourdough
Strider
white JLR
wanderer
Some free feed back, Haha. I love the idea but not the offset 4.5". I see you have a JK, JL Rubicons come with wider axles for a reason and JL Rubicon's are better off with 5.5'ish and less tire poke IMO. I love my AEV wheels (5.7) but would replace them with your new design in a minute if you offered something closer to JL OEM rather than a generic Wrangler offset.
JeepVT
VT
2021 JLURD
Most full lift kids required <4.5 to not rub. I love AEV wheels but cannot use them or my tires will rub. AEV makes beadlocks for a more OEM wheel tuck.
OMTBiker
Derek
Ohio
2021 JLUR White | 2021 JLU 80th Snazzberry
Information Technology
If they came in a +6 (5" B.S.) or +12 (5.25" B.S.) I would consider them. I really like the Rebounds but the backspacing pushes the wheels/tires out too much for me.
sourdough
Strider
white JLR
wanderer
I really like Icon's wheel idea. But I'm with you about the back spacing. I run +25 wheels with 37's, a 2.5" lift and stock fenders on my Rubicon, without rub issues. Icon could one up AEV just by offering their wheel with a Wrangler Rubicon in mind.
OMTBiker
Derek
Ohio
Agreed, I will more then likely to go with AEV this time, I went with Teraflex Nomad (0 offset with 4.75) and they stuck out 2.5+ inches. Love the wheels but would prefer something more tucked.
WheelsASAP
