- Dusty
- Nov 15, 2020
- California
- Website
- iconvehicledynamics.com
- 2015 JKUR
Introducing ICON Impact COMP Series Frame Mounted Sliders for JL!
Equip your Jeep Wrangler JL with the ultimate in hard core rocker protection with ICON Impact COMP Series Frame-Mounted Rock Sliders. These sliders are installed by welding them directly to the strongest structure of the Jeep, the frame itself. Dual heavy-wall DOM tubular sliders with plate steel gussets are rugged enough to bear the weight of the Jeep as it slides across the rocks and maneuvers through the tightest trail obstacles. Three heavy duty fabricated outriggers tie the slider to the frame rail and provide both vertical rigidity and lateral strength for pivoting around rocks while keeping the Jeep's doors and body panels safely distanced from canyon walls. For an extra layer of protection, these Rock Sliders may be installed in conjunction with ICON Impact Body Armor, which acts as an exo-skin protecting the Jeep's rocker sheet metal against any small rocks or branches that make it past the Rock Sliders. COMP Series Frame Mount Sliders are the pinnacle of both function and form, giving the Jeep a hard core, trail ready look. The sliders are finished in a durable semi-gloss black multi-stage powder coat. Wheel with confidence knowing that ICON Impact products are covered by ICON's Limited Lifetime Warranty.
FEATURES & BENEFITS
Here's a closer look at the outriggers and how they mount up (requires welding):
LINKS:
ICON Impact COMP Series Frame Mounted Sliders for JL 4-Door
ICON Impact Body Armor for JL 4-Door
(2-door versions in development)
FEATURES & BENEFITS
- Extreme Duty heavy wall DOM tube and plate steel design to withstand punishment
- Slider outriggers are welded directly to the Jeep's frame rails for the strongest possible rocker protection
- Extreme Duty outriggers are designed for the highest clearance available in a frame-mounted slider
- Frame-mounted sliders absorb impacts with no stress to the Jeep's body sheet metal
- May be used with ICON Impact Body Armor for added body sheet metal protection
- Durable multi-stage semi-gloss black powder coat finish
- ICON Impact Series Limited Lifetime Warranty
LINKS:
