I want to pull a small 5x8 trailer and I need a wiring harness, what do you recommend ?
01tj
jason
Fairmont WV
Previous 2001 Wrangler, Kia Optima, possibly 2018 Wrangler unlimited
I searched and found approximately 10,000 threads but really didn't find what I am looking for. My dad has a 5x8 trailer that accepts a 4 pin wiring harness (7 with an adapter) that I want to pull with my Jeep. I found some plug and play options but they are all for a JK or TJ. Who makes one for a JL?
Steven
Steven
Austin, TX
2020 Jeep Wrangler Unlimited Sahara 4x4
Dad
Any standard 4-to-7 pin adapter will work. You can get them nearly anywhere; Walmart, auto store, U-Haul, ext...
01tj
jason
Fairmont WV
Are they pretty easy to hook up?
Steven
Steven
Austin, TX
Dad
You just plug the adapter into your Jeep and the plug from the trailer into it.
01tj
jason
Fairmont WV
Steven
Steven
Austin, TX
Dad
I think I might be misunderstanding your original question.
Does your Jeep have this?
Jeep Wrangler JL I want to pull a small 5x8 trailer and I need a wiring harness, what do you recommend ? image
Steven
Steven
Austin, TX
Dad
If you have it, you just need to plug your trailer connection into it; no adapter required.
If you don’t have it, then ignore everything I’ve said.
zrickety
Technician
It sounds like you need the harness. I got one from Curt... It's listed for the JL Unlimited but I can confirm it worked on my 2 door Rubicon. You'll need to fish a wire underneath to the battery. It's not hard, bit it is tedious. The other bits plug in behind the tail lights. Look it up on etrailer and buy on Amazon, that's what I did.
Edit- Curt 56407 it's $64 on prime
Here it is wrapped around my tow hook.
Jeep Wrangler JL I want to pull a small 5x8 trailer and I need a wiring harness, what do you recommend ? IMG_20200818_171827586_HDR
Steven
Steven
Austin, TX
Dad
Here is the factory harness from big Q.
zrickety
Technician
01tj
jason
Fairmont WV
Yeah, that's what I need. Why do you have it wrapped around your tow hook? Too much extra wire?
Looks like this is what you have
https://www.amazon.com/Curt-Manufac...243613&sprefix=wrangler+jl+tow,aps,163&sr=8-2
Looks like a lot of wires
zrickety
Technician
https://www.amazon.com/Curt-Manufacturing-56407-Vehicle-Trailer/dp/B07FK93VMF/ref=sr_1_2?crid=1CQZXVE2JIERH&dchild=1&keywords=wrangler+jl+towing+harness&qid=1599243613&sprefix=wrangler+jl+tow,aps,163&sr=8-2
Here is the Q equivalent for $70.
https://www.quadratec.com/p/quadratec/tow-hitch-wiring-harness-wrangler-jl
It's not as many as you think. The tail light harnesses go in their spots, the box sits behind the driver tail, the ground can go on a bolt there, the positive goes up to the battery. That's it. A few zip ties and you're done. It's really not long, I just put it there when I'm not using it.
