zeebo56
- Zee
- Mar 8, 2020
- los angeles
- 2020 jeep wrangler unlimited sport
- Vehicle Showcase
- 1
Actually I'll give you that one and thanks for the info.There are 42,000 miles on these Copper STT Pro tires. I will get 50,000 out of them easily.
One of the big problems with the Pats, are they are a crowned tire when ran it their recommend psi. The contact patch is small as they primary run on the center lug. If you run them in a lower psi so that you have a better contact patch on the street, they will wear and cup bad. That is not the case with many other better tires.
Just for simple math, the cost of two set of Pats + mounting is way more that a better quality tire that last twice as long. Also when running a better tire, you will also get to enjoy a better tire and there is value in that.
In the end of the day, it is your money and you, like I get to spend it how we please. Thank Jeep for your traction control, anti lock brakes and stability control. After all that is what make the Pats a good tire......... Because if they are on a vehicle with out traction control, anti lock brakes or stability control, like they are on my SBXJ, you would not be impressed with their performance.
I guess before the jeep I also had another car that never had tires last long but maybe because I was cheaping out on them as well.
I know you do a lot of cool trips and that tread is pretty good for 40k+ miles
