BoisetheCat
Yes. # of 12v inside. hoping for 2. thanks. greatAre you speaking about the interior 12V? After work today I can take some more photos and share.
Thanks! These are standard on all trims you think?
Yes, even the Sport 2 door lists two 12V outlets as standard.Thanks! These are standard on all trims you think?
My photos are of a Sport S interior. So, if the Sport has them it’s a good bet Sahara and Rubicon do too.Thanks! These are standard on all trims you think?
They will still "fit" but not function quite the same. That's if you still want them after reading all the negative comments about them. The flares have nothing to do with the fit of these extensions as they only bolt to the bumper. The function diminishes because you will create a gap by adding the high flares.I am waiting for my Sport S delivery and now I'm wondering (since I plan on putting the Mopar Rubi fender flares on it in order to accommodate larger tires)...won't these things have to be removed--and not fit back on--with the higher fender flares?
Well good to know they are removable then. ThanksThey will still "fit" but not function quite the same. That's if you still want them after reading all the negative comments about them. The flares have nothing to do with the fit of these extensions as they only bolt to the bumper. The function diminishes because you will create a gap by adding the high flares.
So the plot thickens.I took these pictures at a dealer today on a JLU Sahara with the plastic bumpers. Who will be the first to figure out what it takes to order these plastic rear fill pieces and install them to close it up more?
Sahara and Rubi do (MBA). Sport is a different bumper (MB1).So the plot thickens.
Fog lights exposed on Sport bumpers but enclosed on Sahara bumper. Also exposed on Rubi steel bumpers.
Do the Sport/Sahara/Rubi all share the same plastic bumper other than cosmetic trim?
