I have a mopar lift, do I need any other components?
drdriller
Houston
2019 jl
Do I need to install any other components with my mopar 2 inch lift other than what comes in the box? I’m running a 19 rubicon Jl with 315x75x17 ko2 and fuel 17 inch wheels.
nerubi
Nebraska
2019 JLR, 2020 VW Tiguan
I would need a step ladder to get in and out plus a roof rack to store it on.
DeVoTee
Nebraska
12 JKU Rubicon, 17 JKU Sport on Roids, 18 JLU Rubicon, 19 JL Rubicon ordered, RAM, Range Rover
I would suggest the following: adjustable lower control arms, front track bar, and probably a rear track bar bracket. Oh.. and I would also add front coil spring isolators. Apparently Mopar has upgraded the isolators, but I would spend the $30-$50 for aftermarket. To be safe;)
ECHO
Craig
Pennsylvania
2-Door JL Rubicon - Black
Retired Air Force - Currently in my Dream Job
Nope you don’t.. it’s all inclusive and a good kit I have installed a few already
Roky
Roky
Measure height of your rig before and after lift and if you get over 3 inches you’ll need extra parts. Front and rear adjustable track bars to center your axles, and adjustable front lower control arms to increase caster because the fixed ones that come in kit aren’t long enough. Also go ahead and order you some rock krawler spring isolators, and don’t use the ones in the kit.
Bearman95
Chuck
Ft. Worth
2018 JL Rubicon
I have basically the same set up as you and I did not need any other parts! Worked perfectly out of the box. My dealer installed it with a lifetime warranty!
drdriller
Houston
2019 jl
That's great news. Mine seems to be running fine so far
Brazilbombsqd
Arkansas
2018 JLU Rubicon
Install the Mopar 2" on a 2018 JLUR. The Mopar 2" was more like 4" lift. After the alignment the caster was a 4.2. After driving it for 2 days the steering not what it use to be. So i'm currently looking to install some adjustable front lower control arms. My goal is to set the caster at 5.5.
Notasuv
Space City USA
2018 JL Sport
2018 JL Mopar lift dealer installed running 37's on 20 inch Fuel rims have hit 85 on speedo which is uncalibrated and no serious wobble problems...….in town drives like a charm..over 55 mph your typical brick with over sized tires and short wheel base ride :)
Mattyp1214
Black 2018 JLUR
You should start a thread for those of us with kit if you do this. Let us know how it goes
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
It will drive fine out of the box, but if you are anal like me the axles pushed to one side or the other will drive you nuts. I would personally add a front trackbar and a raised rear trackbar bracket designed for a 3-3.5" lift kit to center the axles.
salty821
Alex
Fort Lauderdale, FL
2019 JLU Sahara
I'm looking at the Fuel Vapors right now! 20x9 or 20x10 with 35x12.5. I have punkn Sahara JLU. Do you like the Matte Black? Did you consider the tinted ones? I haven't seen those in person so not sure what they really look like. They look great on your Jeep!
Brosef
Michael
Chicago
JL 392
I would add adjustable track bars and adjustable upper control arms up front to dial-in your caster. Not necessary, but that’s what you need to get it aligned perfectly (not saying doing it without them isn’t good enough - most people don’t).
demisx
Dee
Desert Hot Springs, CA
Wrangler JLU Rubicon
Did you mean the adjustable front LCAs (Lower Control Arms)?
