ArmyRN
- Paul
- Dec 21, 2022
- Longview, WA
- 1946 Willys CJ2A, 1998 Jeep TJ, 2023 Willys JLU
I've got a 2023 Willys JLU XR (2.0T in Sting Gray). The XR package comes with a 1.5" lift along with a lot of other good stuff that to me, made it worth the extra cost for the XR package (I'm a gear-head). But they put an extra-long bump stop up front (my main issue), and the look with the 1.5" lift and factory 35" tires just didn't look... completed.
Jeep - you should have given us a full 2" lift with the XR package.
So today I installed a set of front & rear Teraflex 0.5" spring spacers (yeah - I know... I went out on a limb there - a whole half-inch!). They're like $50-something for the set depending on where you buy them. The Jeep was already level, so I put them in front & rear. If they (Teraflex) had a 0.75" spacer kit I would have got that instead, but they don't. I mainly wanted to put a little more space between the front bump stop & pad, and lift it just a little without worrying about having to get it aligned and such. And not so much lift that it makes the 35" tires look too small now.
JL: 0.5” Coil Spring Spacer Load Level Kit – Front & Rear (teraflex.com)
Here's before and after:
Install was pretty straight forward. The instructions say to disconnect the track bar front & rear when installing. I didn't, and I got them in. In hindsight, it probably would have been easier if I had disconnected them (would be simple to disconnect - I was just being rebellious).
With the Teraflex spacers they have you reuse your upper rubber pieces, so it is a little bit of a PIA getting the nubs all lined-up when putting the springs back in. If I were to do it again (like wanting to go with a taller spacer), I'd look for a one-piece spacer that doesn't reuse the factory upper rubber parts (if there is such a thing). Or an ACOS up front (which starts with a 1" lift).
Doing the rear, they have you remove the parking brake cable holder at the top of the tub, and they tell you to toss it. Which I did. If you're going to do any kind of rear suspension lift, I'd suggest looking for an emergency brake relocation bracket that has you bring the cables below the crossmember (there's a couple companies that make them - Rancho and Synergy are two that come to mind). Not disconnecting the rear track bar and the tight e-brake cables made it a little more difficult (but doable) for the rear spacer installation.
So now I've got 2.75" of space between the front bump stop and the bump stop pad. And the front shock can only extend about 3" more before it is maxed out. The front shock sits at 21.5" "resting", and maxes out extended at 24.5".
This Willys is my daily driver and road-tripping and light overlanding vehicle (I'm taking it from SW WA to FL and back sometime August/September). I've got a lifted and locked 98 TJ for the rough stuff like threading between trees and over rocks. I think my next suspension upgrade will be to Fox 2.0 shocks in the 2-3" lift variety. I have no intention of going larger than 35" tires - I think the 35" tires and 4.56 gears are just right, and I can barely lift the 35" tires as it is. I'm pleased with how this little project turned out.
I measured the front tires to see how much of a difference one-side stood out from the other. It came out to 1/8" difference from one side to the other (and IIRC it was the passenger side that stuck out more).
