I Bought the extended MOPAR Warranty
Kahuna
New Jersey
2020 JLU Rubicon
So I just bought the extended MOPAR Warranty (max Care). I ended up going with 7 years/60k miles. I paid $990 total and have a $100 dollar deductible. I went through Granger Motors.
What mileage is on your Jeep..I paid a whole lot more on my 2020 a month ago and am guessing it was due to having 60K miles on it.
RAD1
Rob
New England
2024 Willys V6 6MT w SOT Anvil
Engineer
I did get the MOPAR warranty when I got my 2024 Rubicon X 4Xe. Got the 8 year, 125,000 mile $0 deductible warranty. I figured with $0 because a dealer could $100 you to death. Mine is not tied back too the dealer so I am not restricted to where I take it.... as long as it is a MOPAR dealer. My cost was $2,850
That's really cheap. The $25 over cost Granger offer is $4275 for 8 yrs 125K mile, $0 deductible!
Who did you buy it from?
TrentYoung
Trent
Phoenix
2024 Jeep Wrangler Rubicon X 4Xe
Directly from MOPAR over the phone and then my dealership confirmed it was a confirmed price and to take i becaus ethey wouldn't or couldn't match it. Got it 9 months ago.
KrzybonesJLU
Vince
CA, Orange County
2019 JLU SPORT S, 2024 WILLY's
Is there a page that shows the cost of some of these plans and tiers? I can’t for the life of me find a link when searching the web… I understand you can shop around but it be good to see a base line.
m3reno
Sal
caldwell
2022 Jeep Wrangler JLU
That's what I should have bought. I got the unlimited mileage/7 yr warranty/100 dollar deductible for the same price.
rohdawg
Long Island, New York
Merchant Marine
lowmpg
Ryan
Kent Island, Maryland
2021 Rubicon, 2025 Ram Limited
I got max care when I bought mine, 7years/75,000 miles….not sure why yours is 60k. As for what is covered….
COMPONENTS COVERED BY THE PLAN INCLUDE (BUT ARE NOT LIMITED TO):
GASOLINE ENGINE: Cylinder Block and all Internal Parts; Cylinder Head Assemblies; Timing Case, Timing Chain, Timing Belt, Gears and Sprockets; Variable Valve Timing Solenoids and Actuators; Harmonic Balancer; Oil Pump, Water Pump and Housing; Intake and Exhaust Manifolds; Flywheel with Starter Ring Gear; Core Plugs; Valve Covers; Oil Pan; Oil Filter Adapter Housing; Turbocharger Housing and Internal Parts; Turbocharger Wastegate Actuator; Supercharger; Fuel Injectors (excluding clogged injectors); Serpentine Belt Tensioner; Seals and Gaskets.
DIESEL ENGINE: Cylinder Block and all Internal Parts; Cylinder Head Assemblies; Timing Gears and Cover; Harmonic Balancer; Oil Pump; Water Pump and Housing; Intake and Exhaust Manifolds; Core Plugs; Valve Covers; Oil Pan; Turbocharger Housing and Internal Parts; Fuel Injection Pump and Injectors (excluding clogged injectors); High Pressure Oil Pump; High Pressure Oil Rails; Seals and Gaskets.
TRANSMISSION: Transmission Case and all Internal Parts; Torque Converter; Drive/Flex Plate; Transmission Range Switch; Transmission Control Module; Bell Housing; Oil Pan; Gear Shifter and Shifter Mechanism; Seals and Gaskets.
NOTE: MANUAL TRANSMISSION CLUTCH PARTS ARE NOT COVERED AT ANY TIME.
FOUR-WHEEL DRIVE (4x4): Transfer Case and all Internal Parts; Axle Housing and all Internal Parts; Axles Shafts; Axle Shaft Bearings; Drive Shafts Assemblies (Front and Rear); Drive Shaft Center Bearings; Wheel Bearings; Universal Joints and Yokes; Disconnect Housing Assembly; Seals and Gaskets.
ALL-WHEEL DRIVE (AWD): Power Transfer Unit and all Internal Parts; Viscous Coupler; Axle Housing and all Internal parts; Constant Velocity Joints and Boots; Rear Driveline Module; Drive Shaft and Axle Shaft Assemblies; Wheel Bearings; Differential Carrier Assembly and all Internal Parts; Output Bearing; Output Flange; End Cover; Overrunning Clutch; Shift Motor; Vacuum Motor; Torque Tube; Pinion Spacer and Shim; Seals and Gaskets.
FRONT WHEEL DRIVE: Transaxle Case and all Internal Parts; Axle Shaft Assemblies; Constant Velocity Joints and Boots; Shifter Mechanism; Wheel Bearings; Differential Cover; Oil Pan; Transaxle Speed Sensors; Transaxle Solenoid Assembly; PRNDL Position Switch; Transaxle Electronic Controller; Torque Converter; Seals and Gaskets
REAR WHEEL DRIVE: Rear Axle Housing and all Internal Parts; Axle Shafts; Axle Shaft Bearings; Drive Shaft Assemblies; Drive Shaft Center Bearings; Universal Joints and Yokes; Seals and Gaskets.
STEERING: Steering Gear Housing and all Internal Parts; Power Steering Gear; Inner Tie Rods; Outer Tie Rods; Drag Link; Idler Arm; Pitman Arm; Steering Stabilizer; Power Steering Pump and Reservoir; Power Steering Motors; Power Steering Pump Cooler; Steering Shafts (upper and lower); Steering Shaft Lower Coupling; Telescoping Steering Column Motors; Rack and Pinion Assembly; Rack and Pinion Boots; Electronic Steering Motor; Seals and Gaskets.
AIR CONDITIONING/HEATING: Factory or Manufacturer-authorized air conditioning installations only. Air Conditioning Compressor; Clutch; Coil; Condenser; Front Evaporator; Rear Evaporator; Receiver-Drier; Expansion Valve; Hoses and Lines; Low Pressure Cut-off Switch; High Pressure Cut-off Switch; Clutch Cycling Switch; Front Instrument Panel Control Assembly; Rear Instrument Panel Control Assembly; Power Module; Blend Air Door Actuators and Motors; Housing; Front and Rear Air Conditioning/Heater Blower Motor; Blower Motor Resistor; Heater Core; Seals and Gaskets.
ENGINE COOLING & FUEL: Cooling Fan, Clutch and Motor; Radiator; Coolant Temperature Switch; Fuel Pump; Water Pump and Housing; Active Grille Shutter System; Fuel Tank Sending Unit; Fuel Pressure Regulator; Fuel Pressure Sensor; Fuel Tank and Lines; Serpentine Belt Tensioner; Engine Oil Cooler; Transmission Oil Cooler; EGR Cooler; Evaporative Emissions Leak Detection Pump and Monitor; Knock Sensor, Oxygen Sensor, Emissions Maintenance Reminder Module; Intake Air Temperature Sensor, Vapor Canister and Hoses; Seals and Gaskets.
Form Num: NM515
Page: 3 of 10
FRONT SUSPENSION: Shocks; Shock Mounts; Struts; Strut Mounts, Bushings and Bearings; Upper and Lower Control Arms; Control Arm Bushings; Thrust Arms; Upper and Lower Ball Joints; Coil Springs; Torsion Bars; Air Suspension System; Front Wheel Bearings.
REAR SUSPENSION: Rear Leaf Springs; Rear Coil Springs; Auxiliary Springs; Spring Interliner; Spring Bushing; Spring Shackle; U-Bolt Rear Spring; Spring Hanger; Axle Trac Bar; Lateral Link Arm; Shocks; Shock Mount Plate; Struts; Strut Mounting Plates; Strut Bushings; Rear Trailing Arm Assembly; Rear Torsion Arms; Rear Torsion Bars; Rear Stabilizer/Sway Bar; Rear Stabilizer/Sway Bar Link; Rear Stabilizer/Sway Bar Bushing; Rear Wheel Bearings.
BRAKES: Master Cylinder, Assist Booster; Wheel Cylinders; Disc Brake Calipers and Pistons; Brake Lines, Hoses, Fittings; Proportioning Valve; Seals and Gaskets.
NOTE: BRAKE SHOES, PADS, ROTORS, AND DRUMS ARE NOT COVERED AT ANY TIME.
ANTI-LOCK BRAKES (ABS): Brake System’s Hydraulic Assembly; Pump Motor Assembly; Controller; Sensors and Relays; Seals and Gaskets.
ELECTRICAL: Starter Motor and Solenoid; Generator (Alternator); Engine Control Module - (Single Module Engine Controller) (SMEC); Powertrain Control Module; Distributor; Ignition Module; Ignition Coil; Coil Pack Assembly; Voltage Regulator; Horn and Horn Pad; Transmission Control Module; All Wiring Harnesses; Electronic Fuel Injection System (excluding clogged injectors); Windshield Wiper Motor; Rear Window Wiper Motor; Wiper Control Module; Manually Operated Electrical Switches; Neutral Safety Switch; Temperature Sending Unit/Switch; Oil Level and Oil Pressure Sending Unit/Switch; Body Computer; Body Control Module; Factory Installed Radio, Speakers and Rear Entertainment Systems (Includes CD and DVD Player); Factory Installed Navigation Systems (excludes navigation disc); Audio Amplifier; Height Adjustment Compressor; Gateway Module; Ignition Module, Factory Installed U-Connect System.
NOTE: HEADPHONES ARE NOT COVERED AT ANY TIME.
INSTRUMENTATION: Electronic Instrument Cluster; Amp/Voltmeter Gauge; Fuel Gauge; Temperature Gauge; Tachometer; Oil
Pressure Gauge; Turbo Gauge; Speedometer.
KEY FOB: Subject to the limitations in this provision, the Plan provides (i) coverage for up to three key fob repairs or replacements, and (ii) a total key fob coverage benefit of $600, which limit applies notwithstanding the cost per repair or per replacement of the key fob for the Covered Vehicle. Key fob coverage is available even if any part of this covered component is not available, recoverable or operable, and this coverage is not subject to the deductible that applies to repair visits for covered components.
NOTE: FAILURE OF A KEY FOB BATTERY DOES NOT CONSTITUTE A MECHANICAL FAILURE OF THE KEY FOB.
POWER GROUP: Rear Window Defroster; Power Window Motors; Power Window Flex Track; Power Antenna; Power Seat Motors; Power Door Locks and Linkage; Power Sliding Rear Window Motor and Regulator (Trucks); Power Sliding Door Motors; Power Liftgate; Vacuum Pump.
LUXURY GROUP: Keyless Entry Sensors and Receiver/Module; Trip Computer; Message Center; Overhead Electronic Vehicle Information Center; Overhead Electronic Compass/Temperature; Power Sunroof Motor; Convertible Top Motor; Electric Mirror Motor and Controls; Cruise Control Servo; Headlight Door Motor; Concealed Headlamp Module; Park Assist Module; Park Assist Sensors; Back Up Assist Camera; Door Latches; Heated Seat Systems; Factory Installed Remote Start System; Heated Steering Wheel; In-Vehicle Wireless Charging Station; USB Outlets; 120V Outlets.
ENGINE EMISSIONS: Air Pump; Air Supply Hose; Leak Detection Pump; Evaporative System Detector/Monitor; Vapor Canister; Air Injection Valve; EGR Valve; EGR Cooler; Aspirator Tube; Fuel Tank Pressure Sensor; EGR Tube; Purge Solenoid; Knock Sensor; Oxygen Sensor; Diesel Exhaust Fluid (DEF) System.
NOTE: CATALYTIC CONVERTOR AND PARTICULATE FILTER ARE NOT COVERED.
SAFETY SYSTEMS: Airbags (excluding deployed airbags); Impact Sensors; Occupancy Sensors; Seatbelt Retractors; Seat Belt Buckles; Modules; Sensors; and Switches.
NOTE: AIR BAGS THAT HAVE BEEN DEPLOYED ARE NOT COVERED AT ANYTIME.
MOPAR ACCESSORIES: All electrical and mechanical Mopar accessories are covered provided they were installed by an authorized Dealer; Audio Systems (including Compact Disc Players); Sirius Satellite Radio; Speed Control; EVS (Security Systems); Clocks; Remote Trunk Release; Transmission Oil Cooler; Remote Control Outside Mirrors; Power Sliding Rear Window Assembly (Trucks); Rear Seat Video Entertainment Systems (including DVD Players); Remote Start System (excluding transmitters); MoparConnect. NOTE: MOPAR PERFORMANCE PARTS ARE NOT COVERED AT ANY TIME
Form Num: NM515
Page: 4 of 10
MOPAR LIFT KIT COVERAGE: If you purchased this coverage as shown on the front page, you have coverage for Mopar lift kits and related parts that are professionally installed, including performance parts pertaining to the lift kit (maximum 4 inch combined lift). If the Mopar Lift Kit coverage is not indicated on the front page, there is no coverage.
OTHER PLAN BENEFITS: The Plan also provides the following Trip Interruption, First Day Rental, Rental Allowance, Taxi Reimbursement, and Roadside Assistance benefits.
TRIP INTERRUPTION: The Plan will pay up to $1000 for lodging, meals, and emergency transportation such as taxi, bus, or airline for you and your family if (1) your vehicle is inoperable due to a failure covered under this Plan or under the factory warranty, and (2) you are more than 100 miles from the address of record. Lodging, meals and car rental receipts must accompany a copy of repair bill and must be emailed to [email protected]. If this is not an option, you can mail to Vehicle Protection, P.O. Box 2700, Troy, Michigan 48007-2700. Please be advised that the mail in process is a longer process.
FIRST DAY RENTAL: First Day Rental Allowance provides up to $35.00 car rental allowance if the Vehicle is to be serviced for any mechanical repair or maintenance service. Please note: Excludes rental for bodywork to the exterior sheet metal/composite panel or collision repairs.
RENTAL ALLOWANCE: Rental Allowance will pay up to $35.00 per day for a rental any time repairs take overnight, and a component covered by the Plan or the manufacturer’s Basic or Powertrain Warranty fails.
The Plan will not pay for rental charges for a vehicle that is awaiting service or parts unless the vehicle is inoperable due to a mechanical failure of a covered component, or unless continued operation would cause further damage.
The rental vehicle must be obtained from a Dealer. If a Dealer does not have rental vehicles available, you may obtain one from a licensed rental agency. Rental coverage is subject to state and local laws and policies imposed by the rental agency. Rental charges in excess of the amount allowed by the Plan are your responsibility. The Plan is not responsible for any refusal of a rental agency to rent a vehicle to you.
RAD1
Rob
New England
Engineer
Did you get the max care warranty for $2850? I see a Mopar direct warranty called Added Care Plus 8 years / 125K miles / $0 deductible for $2850. Max Care is $4650. Added Care covers 850 components. Max Care covers 5000 components.
Kleiss1
Gary
Arizona
2021 JLURD 2018 Mustang GT 6-sp.
Do any cover the diesel particulate filter? Is that a big dollar item? Thanks
TrentYoung
Trent
Phoenix
I did and would do the Max Care. However, call them on the phone and negotiate. Do not take their first offer... they will go lower. Just tell them you are poor and you would really like to go with them but your are price conscious.
Steemax
Los Angeles
2022 Rubicon 4xE
I'm looking at purchasing one as well and I see you also have a 4xe... Were you able to find any info on if any of the PHEV components are covered? I couldn't find any mention of it on the warranty site.
TrentYoung
Trent
Phoenix
I do not remember the specifics. But I did learn they covered much more than anything any of the dealers offered. My dealer, and friend, suggested MOPAR warranty as a much better value and product.
