NyRey87
Hey all I have a question maybe you guys can help me out.
I have My 2020 JLU Sport and I have a Clayton Off-Road 2.5 overland kit with fox 2.0's on Toyo 285x75x17's. I will be upgrading the axles to Rubicon hopefully soonish. My current wheel and tire combo puts me at about 85 almost 86lbs per, stock is around 73lbs. I am very weight conscious on my Jeep mainly because I have the 30/35 combo and its my daily driver but I do get out on the trails once every couple weeks. But I plan on picking up a set of C rated 37x12.5x17's in the near future. I am essentially only gaining 4lbs per tire compared to my current setup. Other than the gears being the 3.45 and the axles being on the weaker side would this create a lot more wear than my current set?
I guess basically I want to know if you had a heavier 35" tire wheel combo compared to a lighter 37" tire combo that was essentially the same weight would the increase in diameter cause more wear than the 35" set? Hopefully that makes sense. Thanks !
