JamesKelly
I bought a 2019 rubi with a lift already installed but I have no idea how to tell how much. Any ideas?
measure from center of wheel (or ground to fender and post your tire size) to bottom of fender and post it up here . someone with a similar vehicle will have the stock measurements for you to compare to i'm sure
I can get it to you tomorrow it’s in the garage right now.How about a pic as well? And maybe a pic of the suspension? Front and rear coils and/or shocks.
There are several different ways to measure, but I like to measure from the top of the axle to the bottom edge of the top spring housing. Then if you can stop at dealership and measure one on the lot, or maybe someone on here rocking it stock might chime in.......I bought a 2019 rubi with a lift already installed but I have no idea how to tell how much. Any ideas?
I can’t believe I can’t find measurements online. Like what is stock so I can see what I have and figure it outThere are several different ways to measure, but I like to measure from the top of the axle to the bottom edge of the top spring housing. Then if you can stop at dealership and measure one on the lot, or maybe someone on here rocking it stock might chime in.......
I have to get under there and check tomorrow. I’ll send pics of it when I get out there.Does it have fox shocks? With 35s it’s probably around a 2 inch or so lift. If fox shocks maybe it has the mopar lift.
I asked @Kimberly , and she was gracious enough to measure her 2020 Rubi like this..I have to get under there and check tomorrow. I’ll send pics of it when I get out there.
12” coil? What lift does she have on hers? That gives me nothing to compare to lolI asked @Kimberly , and she was gracious enough to measure her 2020 Rubi like this..
she got 12”, so if you measure yours it should give you the amount of lift you have....ish.....
Thanks again Kim.
She’s on a stock Rubi, the picture is mine ,it’s only to show location to measure. She has 12” in this location, if you measure yours and let’s say it measures 14” then you have a 2” lift.12” coil? What lift does she have on hers? That gives me nothing to compare to lol
I just measured my Rubi XR in this fashion it is suppose to be a 1.5” lift but I get 12” this way. But if i measure from center of hub to fender lip I get 25.25”.She’s on a stock Rubi, the picture is mine ,it’s only to show location to measure. She has 12” in this location, if you measure yours and let’s say it measures 14” then you have a 2” lift.
