Renegade Wrangler
- Gasan
- Oct 14, 2018
- Atlanta, GA
- Wrangler JL Rubicon
- Occupation
- Spice Man
I did a 4 channel amp with components in the kick panels with the tweeters on the dash and components in the soundbar, now I want to run a separate amp for the sub and did not want to change the enclosure. Just like what you did, I don't think anyone did that yet. I put the DSR1 Fosgate to use the preamplifier signal from the 8.4 alpine system. I am running all Focal system. So the sub you are using obviously its protruding a bit from the enclosure, which one is it so I can get the measurements also did you do any cutting to the enclosure, back side or around the sub. Thanks in advance.
