How to Install Oracle Lighting Pre- Runner LED Grill Kit for Jeep JL?
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
The Oracle Lighting Pre Runner style LED Grill Kit for Jeep Wrangler JL allows you to add 3x LED Marker Lights to the front Grill of your Jeep Wrangler JL without any cutting or drilling. These super-bright 3-Watt LEDs make your Wrangler stand out and can be connected to your parking lights, Daytime Running Lights, or to an Auxiliary Switch.
Other colors are available. (Only Amber and White can be used On-Road.)
Kit Includes following:
- (3) 3W LED Billet Bolt Lights.
- Wiring Connectors, Cables, and Hardware.
- Installation Instructions.
Installation Video!
Check out the PDF Install guide HERE.
Comment below with any photos /videos with your step by step installation or completed mod! :like:
Dave928
Washington
2020 JLU Rubicon, 03 Silverado, 88 Porsche 928 S4
Aircraft Tech
does the center light fit if you have the Bolt hood lock installed?
ORACLElights
ORACLElights
Metairie, LA
U
Good question. Unfortunately we do not have that to try it on. We do have a 30 day return policy if this part does not end up working out.
cjmdwyer
Arizona
2020 JLUR 2.0 sting gray
The center one can not be installed as shown due to a horn being there! What’s up with that???
ORACLElights
ORACLElights
Metairie, LA
We have installed the middle on our JL and in the installation video:
cjmdwyer
Arizona
My bad, its not the center one, it's the outer ones, the horns are in the way when you try to put grille back on!
I have a 2020 with the 2.0 turbo if that matters. Almost looks like the "bolt lights" in the video are shorter than the ones I received. Weird....
packmanjlrubi
Anthony
PA
2000 TJ, 2018 JLUR
Any Answers? I just got mine and was looking at where they should go and the horns definitely look like they will be in the way. 2018 JLUR
donmontalvo
Don
Plano, TX
donmontalvo.com
2021 Jeep Wrangler Unlimited Rubicon (Snazzberry)
Systems Engineer
I'm preparing for a long trip in April (to/from ESJ), and installed a Bolt lock just because.
I want to buy these pre-runner stile triple LED lights, can I mount them a couple inches lower to avoid the Bolt lock?
ORACLElights
ORACLElights
Metairie, LA
Sure, installing this way will be fine.
Sanchese
Carlos
Toronto, Canada
2021Rubicon, 2022 Rubicon Xtreme Recon on Order
If you have the offroad Camera then where would you suggest we install that middle light?
ORACLElights
ORACLElights
Metairie, LA
Something like this could be a good option for you to avoid the camera.
Jeep Wrangler JL How to Install Oracle Lighting Pre- Runner LED Grill Kit for Jeep JL? _10227694151121361_6741467694910945406_n_1024x1024
Or this JT customer had a different idea with the cam
Jeep Wrangler JL How to Install Oracle Lighting Pre- Runner LED Grill Kit for Jeep JL? 228BCCF8-E104-4653-9116-1CB3A6126A0B_1024x1024
donmontalvo
Don
Plano, TX
donmontalvo.com
Systems Engineer
I like the lights being an inch or two lower to not interfere with the Bolt lock (or camera).
1Evil55
here
2018 Sport
@ORACLElights where do you suggest tapping into power for those without DRL but want the lights on when the Jeep is on?
ORACLElights
ORACLElights
Metairie, LA
If you want this on all the time I would suggest tapping this into your ignition wire in your harness, or to the ignition fuse.
l1lypad
2018 Jeep Wrangler Unlimited Sport S
Could I technically turn these lights into turn signals?
