How to install dashcam with ACC?
James Cole
NY
JL
Hello Guys,
I am trying to install a dashcam and saw the guide for powered mirror but I have ACC, is there a guide somewhere on how to open the ACC box and get a wire from there?
Thanks!
JC
jthoms1
Charlotte
2019 Rubicon Unlimited
Hello Guys,
Thanks!
JC
Sub’d
Snowshoes
Vancouver, BC
1996 ZJ 5.2 / 2018 JL 3.6
If you just want it while you're driving, not so difficult. Plenty of wires to tap. But if you want to use parking mode (hardwire), you typically need a wire/fuse with power at all times (always hot), a wire/fuse with power when the vehicle is running (hot in start) and ground. I tried tapping a lot of wires which I thought powered at all times (always hot) went off several minutes after the jeep was off and locked. JLs don't have fuse box in the cabin so have to run wires through the firewall.
James Cole
NY
JL
  • Thread starter
  • Thread Starter
  • #5
Thanks, I am looking for something that is live ONLY when the truck is on and start/stop active...
Is there anywhere else I can tap into?
James Cole
NY
JL
  • Thread starter
  • Thread Starter
  • #7
Snowshoes
Vancouver, BC
Sonny Hooper
SWVA
I just did this the other day. I used the Quadratec power harness that plugs in behind the 12 volt power outlet in the dash. Bought a 12 volt power outlet with positive and negative wires and hooked them up to the Quadratec harness and plugged the dash cam USB adapter in. No cutting. Totally hidden with zip ties under the dash. Easy.
Here you go:
https://www.quadratec.com/p/quadratec/12-volt-power-adapter-jeep-wrangler-jl
https://www.amazon.com/attwood-11862-6-12V-Marine-Outlet/dp/B003EET3XY
DaddyEngineer
Tomball Texas
2019 JLU Rubicon
Here you go:
That’s what I was thinking about, but using a USB one instead of the cigarette lighter receptical. Thanks for confirming that it works.
cwadle
cameron
Rochester Hills, MI
2019 Granite JLUR
Here you go:
Thats a Great solution, Just bought the parts to do it myself, Thanks!
James Cole
NY
JL
  • Thread starter
  • Thread Starter
  • #13
Guys, just tackled this myself, its exactly the same as non-acc.
Only difference is remove the four push pins that have a phillips plastic screw on the "box" of the acc, everything comes down when pulling the panels around the mirror assy.
cwadle
cameron
Rochester Hills, MI
2019 Granite JLUR
Did it today, works like a charm. Wouldn’t recommend routing it the method they suggested. Found it much more accessible to route the harness through a gap into the area behind the glove box. Keep in mind not to attach the wiring harness to the cooling pipes, or the cabin air filter housing.
treadmark
Greensboro, NC
2019 JLUR & 2017 VW Golf R
Manager
The Quadratec adapter is ignition controlled. Is anyone aware of a continuously powered option?
Here you go:
