roaniecowpony
I do this at least once a year to all our vehicles.
Where did you find that label? My 3.6 only has a label for the AC refrigerant.
Noticed that the other day.
Left side, above the radiatorWhere did you find that label? My 3.6 only has a label for the AC refrigerant.
Chapin makes a little one hand 48 oz version of the pump that I have on my wash cart. Helps with getting the undercarriage degreased as well.When mine gets like that I use a pump up sprayer. Tank type used for spraying weed killer and the like. Low pressure Only and just try to wet all surfaces with soapy water. Then take rags and an assortment of brushes to get into places your hands cannot reach well. Then I get the sprayer going with clean rinse water and gently rinse it down, or hose on really low spray.
It works easier if the engine is slightly warmed up (not Hot) but just warmed up a bit. Also warm water, and I use dish washing soap, it cuts grease to a point and is not harsh on rubber hoses or wire wraps. I stay away from brake cleaners and other solvent type cleaners, they will damage rubber and plastic parts . The long skinny brushes they sell for cleaning wheels are handy, and long bristle paint brushes help for nooks and crannies.
Never had a problem ding it this way. Your engine gets sprayed much harder than that driving in the rain at 70 MPH and hitting puddles....
Don't forget to drink a few stews" and put on some tunes, you may enjoy it, beets washing dishes.
Needless to say don't squirt soap or water into your air intake that is now open because your hood is up...... That is not an insult just saying.
Thank you!!! Yes, I did see the air intake when I was taking the photos, its off to the passenger side. I'll probably plug that up with a towel and some tape. My preference is to wash it at low pressure, including the liner. That seems like the easiest option. Avoiding visible electrical parts. And then going in with my hands and a small brush. This has been helpful. Much appreciated.Nope just watch the air intake that meets the hood when closed.
Someone else mentioned not wetting the hood liner, it never hurt mine. They get wet every time you drive hwy in rain, but if your concerned about it use a vacuum cleaner with the brush attachment on.
Thank you for this!!! I will avoid these. No oils or gunk. Just some dirt. Planning on just using water at first and a light brushing if needed. Someone did mention that dish soap is harmless to the metals and plastics in the engine bay. So that would have been step two if needed.Just a headsup. Simple Green and similar detergents cause aluminum corrosion. You squirt the engine down with these cleaners and pressure wash it, it'll corrode. Ask me how I know. These cleaners are not approved to clean aluminum aircraft..
If you are cleaning oily gunk, the diesel based cleaners will tend to protect the metal.
