How to check if LSD is working properly?
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Anyone with working LSD can check if rear tires will spin in the same or opposite direction when jacked up?
Mine comes with LSD but appears to be spinning in the opposite direction. (Suggesting open diff or due to lack of load?)
Arterius2
Arterius2
Jerry
Vancouver, BC
aldo98229
Aldo
Bellingham, WA
Market Research
Generally LSDs don’t just “stop working properly.” Particularly on a new vehicle. They tend to be pretty robust. They will wear with time, but nothing that should happen this soon.
Arterius2
Arterius2
Jerry
Vancouver, BC
If you read through 40 something pages of the “Knock in rear with D44” thread, we can deduce that the LSD in the JLs are generally faulty from the factory:
https://www.jlwranglerforums.com/forum/threads/knock-in-rear-with-dana-44.16921/page-2
I posted this thread to see if others are getting the same results.
Do you have LSD?
OilBurnerHoldOut
Richard (Rich)
Narnia
07 Ford Edge, 76 Yamaha xs 500, and 89 Honda PC800
UPS Worldport 1DA
I was under the impression that the "anti-spin" differential from the factory was a torsen type. Meaning that if there were no load (IE, wheels in the air) it would not split torque, and would operate as an open diff would.
Arterius2
Arterius2
Jerry
Vancouver, BC
Interesting, this is news to me, but I somewhat suspected this when I saw a few of them were doing the same thing.
Roky
Roky
This is what I was told also when I asked about it when I had my Sahara. It had a Dana 44 with lsd.
aldo98229
Aldo
Bellingham, WA
Market Research
Do you have LSD?
Yes, mine has LSD.
“Trac-Lok” is the official product name of the LSD Jeep uses on Wranglers. It is a clutch-based LSD developed by Dana Corporation.
Feel free to Google the Trac-Lok product name; you will get thousands of results, including explanations of how Trac-Lok works, how it differs from traditional LSDs, its strengths and weaknesses, etc.
Good luck.
SecondTJ
Il
Jeep
How many miles on it? Trac-lok has never been known for longevity, it’s possible the clutch packs can wear out in as little as 30k.
If your still under warranty it’s covered to rebuild it.
LowCountry
allen
Savannah Ga
2018 Billet Sport
Mine spins the same as yours when ive checked it before while rotating tires, etc. I have been curious about it also because I had read both should spin in same direction. I definitely have the D44 and have "checked" it before by spinning in dirt and seeing 2 tracks so im not sure whats up
MtCamper
Ken
NW Montana and Yuma Az
2018 jlUR White Rubi, 2018 GMC 3500 Duramax,
Retired Snowbird
My how times change. 50 years ago you could easily find someone who could tell you if LSD worked or not. Timothy Leary comes to mind. Now you ask a question like this and Jeeps pop into the conversation.
HoundDude
New Jersey (i know, i know, i'm stuck here)
2019 Wrangler JL Sahara
I have the LSD with 12k miles and no knocking sound while coasting. yet.
when I lift the rear and rotate one wheel, there is significant resistance (vehicle in park) + a repetitive knocking sound + other wheel spins in opposite direction.
aldo98229
Aldo
Bellingham, WA
Market Research
My plan is when the Trac-Lok wears out, to replace it with a Detroit TrueTrac. Those things last forever.
