How to adjust?
alltimesaresoon
dave
el paso
fiat 124 spider abarth
Passenger side windnoise as the edge doesn't get pulled all the way in the slot....
The back metal rod is in the rail hole, but still...
I probably have something misaligned?
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
I would ensure the Z clip on that side is installed correctly, if it’s not correctly in the hole in the back it won’t allow the top on that side to be pulled taunt when closed.
WranglerMan
Will
Katy Texas
Gas Pipeliner
The back part of the SR should lay within the rail flat and yours appears to be bunched up alittle so it’s possible that clip is either not in or not in correctly
Here is mine and it lays in the side rails all the way across on both sides
WranglerMan
Will
Katy Texas
Gas Pipeliner
Here’s another shot of how that dam Z clip needs to fit in that hole, they recommend using a piece of black tape over it once installed to keep it in place and remove once installed.
alltimesaresoon
alltimesaresoon
dave
el paso
Sure enough. What was tricking me was that I could see it was in place .....and it still is.......but it broke!
Wonder if besttop will send me a replacement wire
alltimesaresoon
alltimesaresoon
dave
el paso
bad news good news story......
bad news.... bestop help line is very busy, took me about 5 times calling in to connect and a total of about 3 hours on hold
good news.... bestop service people are very nice and very helpful once you get them
bad news... the z clip and wire are NOT repairable/replaceable
good news... i'm under warranty at just over 2 years, and a replacement top will be in stock in a week and ship out to me free of charge. Thank you Bestop!
WranglerMan
Will
Katy Texas
Gas Pipeliner
Glad they are sending you a new top, I’m hoping this is not a weak spot that is prone to breaking…
I have only had mine in a short period but love the simplicity of flipping just a few levers and nothing to store.
Bestop
Summit Sponsor (Level 3)
The Bestop Team
Louisville, CO
2010 JKU
@alltimesaresoon Sorry for the trouble, but I'm glad we could get you straightened out!
@WranglerMan I absolutely wouldn't say this is a weak spot. The Sunrider for Hardtop is a very sturdy product. We sell too many of these and have too good of a warranty to have a weak spot ;)
Lee
- the Bestop team
www.bestop.com
WranglerMan
Will
Katy Texas
Gas Pipeliner
Lee
- the Bestop team
www.bestop.com
Lee,
Thanks for the reply, yes your SR looks and feels like a solid product and mine has performed flawlessly since installing and I have zero issues and the warranty that backs it indicates your great and stand behind the product, I have only heard about a few of the Z clips breaking from the wire but things do happen so no worries.
alltimesaresoon
alltimesaresoon
dave
el paso
Repair attempt......bicycle wire and a butt splice kit.......gonna work?
WranglerMan
Will
Katy Texas
Gas Pipeliner
I would think it might work but the wire I would think would have to be broke away from the end of the Z clip because if it’s broken at the end how would you attaché the clip to it ?
alltimesaresoon
alltimesaresoon
dave
el paso
Round plug end of wire from current top goes in and through the butt splice, set screw keeps it there. Bike wire goes into the z hook hole with plug end behind the slot, then wire into the butt splice. Tension it correctly then set the screws and crimp on the bike wire end piece for extra safety, then cut bike wire
WranglerMan
Will
Katy Texas
Gas Pipeliner
I would like to see the Z clip attached
alltimesaresoon
alltimesaresoon
dave
el paso
The z clip is broken.
alltimesaresoon
alltimesaresoon
dave
el paso
See OP
Rock Krawler
