Old Jeeper
WOW I am amazed at some of the problems in this thread.
I started out driving on a Ford 9N tractor and IIRC I don't think it was fully synchronized trans. I just bought a JLR and first time in my life my Jeep has an auto trans only because the wife demanded it in CASE she drove it in lieu of her 21 Glad.
Truthfully: I was buying a 2004 Jeep TJ Rubicon with 39XX miles on it, all original OEM. Guy bought it and had a stroke before it arrived and he drove around the neighborhood about 1 or 2 x a month till he died and it was an estate sale and first guy to show up with $44,000 got it. I was on the way and they called and said somebody else from Ohio has shown up and got, I was driving from Naples FL to Miami where it at...and that is how I ordered a JLR
I have come to the conclusion on the forum that I should have found another TJ. I had about 100k miles on my TJR 2003 vintage and I WHEELED IT and I had retired and wheeled it all over the SW US from Tx to Cali. My clutch never failed or faltered.
My Clutch in my 64 Corvette did not fail but the throwout bearing did at 103k miles, so I replaced the clutch and PP anyhow.
My 69 Corvette 427/435 hp, throwout bearing failed at 13X,XXX miles, clutch still good, but replaced in and the PP anyhow.
Of all the Jeeps and Corvettes I have owned since '64 never replaced needed to replace a clutch but did due to the bearing failure.
Takeaway: Clutches will outlast throwout bearings.
If your clutch does not last at least 100k miles you might want to look at your left foot and shoe size.
Centerforce clutches: YEP, GREAT product, made for the track and you spend $3k on it in a heartbeat. I recommend them but skip on the trick clutch setups (meant for racers), you just need a solid HD clutch & PP and maybe your new Flywheel. If you have heat cracks on the face of your flywheel REPLACE IT. Always replace as a PACKAGE meaning the Pressure Plate, Throwout bearing, Clutch plate and flywheel all come from the same mfg as a matched set.
I ran Centerforce back in my racing days in the 60s. The guys that mixed parts from different mfg always had premature failures. From Blowing up on the line before they dumped the clutch to exploding on the 1 st > 2 nd power shift at 7000+ rpm.
Looking for a LOW mileage TJR, anyone got one in trade for a JLR...
