How many batteries do I have
drdriller
Houston
2019 jl
I have the 3.6 engine. How many batteries do I have? I only find one when I’m looking, but I read that there may be 2.
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
Yes there are two, the second one is a smaller ESS battery that is buried under the first one
drdriller
Houston
2019 jl
  • Thread starter
  • Thread Starter
  • #3
Shoot, you mean you need to pull out bigger battery to get to the smaller EES under it?
MidMo
Mid Missouri
1999 TJ / 2001 WJ / 2017 Ram 3500HD / 2019 JLU Moab
From what I've seen on video...yes. It's under the main battery and to the rear of it. It's not to convenient to get to.
krucam
DFW, TX
Nissan Xterra, 2019 JLR ordered 12/22/2018
FAA
Do the 2.0 T4 have 3 total? 2 under hood, 1 48V along the frame underneath?
WranglerMan
Will
Katy Texas
Gas Pipeliner
I could think of one reason putting it where they did and that would be most ppl won’t even try to pull the second battery and will take it to the dealer, the engineers honestly could have made room somewhere so it was more easily accessible
drdriller
Houston
2019 jl
  • Thread starter
  • Thread Starter
  • #10
I was just wondering. Does the Jeep still run if one battery dies?
SecondTJ
Il
Jeep
You might be thinking of the cooling systems, of which the 2.0 has three different ones
1) engine
2) intercooler
3) 48V battery
ToolMan514
Tim
Montréal, Québec, Canada
'18 Rubicon Unlimited
The 3.6L Wrangler will not run (start) if either battery is too low, or bad. Also, jump-starting is a longer process, since the AUX battery must come back up to normal voltage before it will start. Since the vehicle electronics need constant power through a stop-start cycle, they run on only on the AUX and the main battery cranks the starter and ignition. Battery charge voltage will fluctuage a lot too -- from 12V to 14V -- depending on what state the system is in. Most of this is in the Owner's Manual.
drdriller
Houston
2019 jl
  • Thread starter
  • Thread Starter
  • #14
Thanks jeepsterfreak. They didn’t put an owners manual in my 19 jl
cns721
Rochester NY
'04 WJ, '13 JKU Sahara, '18 WK2 High Altitude, '19 JLUR
Software Developer
You actually can request a manual to be sent to you for free through Jeep Customer Service. I got mine and it is THICK.
PSC Motorsports
