How fast is too fast in 4H?
R3D J33P
JC
Ohio
2018 JLUR - Firecracker Red
So with a Rubicon in 4 High...how fast is too fast to be driving down the road? Obviously 65-70 MPH is probably too high but just for curiosity what is your experience? I know that driving in 4 High on a Rubicon is going to be different than 4 Auto in a Sahara.
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
Im pretty sure theres no speed limit for 4h, as fast as you feel safe/comfortable. 4low has a limit
homerun
Fort Collins, Colorado
1996 XJ, 2004 Ford Ranger, 2013 Subaru Impreza, 1996 HD Springer Softtail, past jeep 1995 YJ
The answer to your question has much more to do with the traction of the road surface, followed by are you driving completely straight or how tight our the turns/curves. Speed for me is like the 3rd or 4th consideration when using 4H.
R3D J33P
R3D J33P
JC
Ohio
Usually the same for me. I am only thinking the off case the roads are snow covered but still manageable for a 55 MPH speed but more or less a piece of mind that if I hit something nasty or drifted snow I have the Jeep in 4x4.
Uhdinator
Maine
2018 JL Sport HT 2.0T Auto, 2003 TJ Rubicon HT
If 4H is required then I'm usually 50mph or less, as I don't use it unless the road surface is 90-100% snow covered.
wolfdog
George
Southern Massachusetts
2006 Yamaha FJR1300, 2015 Cherokee TH, 2018 JLU Sahara
Maritime Artisan, Mayflower II
I think if you're using 4 High in conditions you need it 70+ won't hurt the Jeep! That is of course that you remember it has NO susuperior brakes so that trip into the center strip could hurt your jeep!
I've done 60+ when I probably shouldn't have and had never had a vehicle problem. Any stopping advantage is only in engine braking with winter tires, otherwise it's just like a Buick!
Hve fun be always careful!
Go Jeep!!!
Capt-Zoom
Capt-Zoom
North
2019 JL sport s, 4door. 1999 TJ Sport
Grew up and lived I northern Mn dealing with a lot of snow and ice . Pretty much everyone drives the speed limit or higher even with 4x4. So about 70-75. Never hurt any of my jeeps, never had axle or diff , trans, transfer, motor or clutch issues. I wouldn't worry about it...just drive within your and your tires abilities.
nerubi
Nebraska
2019 JLR, 2020 VW Tiguan
Yep, reason many vehicles in ditch are suvs, driving faster than you should because common sense goes out the window in one.
Rploaded
Houston
2019 JLUR
When the shiny side is no longer up you’ve gone too fast. In all seriousness speed should be way down on your list of importance if 4h is being used.
Edited* spelling.
TopLift Pros
