How Far does -12 Offset actually stick out from the fender well?
JDM23
Josh
Boulder City, NV
2005 Dodge Ram
Metalcloak lifts are one of the most flexible mid arm systems out there. Because of that, they include shock relocation brackets that move them outwards to clear the frame at full wheel droop. You're best off with a backspace no bigger than 4.5".
I've got the 3.5" Gamechanger, and 38x13.5 Pat's with 17x9 wheels with 4.53" of backspace and a -12 offset.
Do you have a side shot of your set up??
joegrasse
Nebraska
2021 Red JLUR
That pic was an earlier one, before I started really dialing it in. The front tire was about 41" off the ground in that pic, but I've since gotten nearly 6 more inches of height out of the lift.
Thanks buddy!
I’m curious, what did you do to further dial it in?
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
I still had the full set of Synergy's control arms, from my 1st lift, which aren't designed for a lot of flex. Also, the 38's were contacting the rear body pinch seam a couple of inches before the wheel was fully stuffed into the bump stops. I now have all Metalcloak arms and I shortened the rear arms to minimize hitting the body. I still need to trim the seams to get the last inch or so of travel.
Chrysler Factory Warranty
