How far do Rubicon's with 35's (12.5 in wide) and -12 offset rims stick out from fenders?
mjd3d9
2019 JL Rubicon
Cant decide if these will stick out too far. Some side shots would be awesome. Thanks!
ericdrob67
Eric
Michigan
'21 JLUR EcoDiesel, '19 GMC Terrain, '16 Suburban
depends on what wheel you have.... 17x9 -6 offset/4.75"bs
IndustrialAction
Patrick
Slower Lower Delaware
2019 Wrangler JLUR
Mine are getting put on now. I'll post pics when done. I think the offset calculator shows them out ~2"
mjd3d9
2019 JL Rubicon
It would be XD rim with -12 offset.
IndustrialAction
Patrick
2019 Wrangler JLUR
IndustrialAction
Patrick
2019 Wrangler JLUR
mjd3d9
2019 JL Rubicon
Thanks man. That helps a lot. Would you share some side pictures as well so I can see the side stance and the clearance from the fenders to the tire?
jellis4148
Missouri
2019 Jeep Wrangler JLU Rubicon
Here you go...fresh off the lift
So, the wheels I want, are -18 offset. Your Jeep doesn't look like it has a lift. Do your tires rub. In your opinion, do you think a -18 offset with 35,x12.50's will rub?
IndustrialAction
Patrick
2019 Wrangler JLUR
The offset won’t make them rub. I don’t have a lift. It might rub off-road (haven’t tested yet) but on road is no problem with 35s
UKCATS
DFW
2020 JLUR Recon/2020 Mazda3 Hatchback
I play piano in a whorehouse
-12 offset could stick out a little a lot. Depends on the width of the wheel. Backspacing is what matters. Look at all the -12 offset wheels on the following chart.
jellis4148
Missouri
Well, the wheel is a 20x10. Does that help any? I have asked and looked all over for an answer and no one will tell me.
UKCATS
DFW
What is the question?
