How do I know if I have towing package?
NORCAL_916
Paul
Roseville CA
18 Jeep Wrangler JL
I have a 18 Wrangler JLU sport. My question is I am the second owner, how do I know if I have the towing package? Changing my rear diff fluid just wanna make sure I get the correct fluid. Thanks.
aldo98229
Aldo
Bellingham, WA
Market Research
Jmos4
Jim
2020 Challenger Scat Pack M6/2007 Ram 2500 G56
Hi,
Does it have a limited slip I believe is the correct question, jack the rear up spin the tire by hand if the other tire spins the same direction it's got a limited slip if it turns opposite then open.
Or look up the build sheet
Regards,
Jim
aldo98229
Aldo
Bellingham, WA
Market Research
It's saying not a vin
If you are copying and pasting, you must have a space at the start or at the end of the VIN. Make sure there are NO spaces or it won't recognize it.
jludave
The Isle of Long
IT Manager
Or a trailer hitch?
OP could have a hitch without the towing package. It could have been installed after the fact by the original owner. A hitch alone, is not a true indicator of having the tow package.
Old Dogger
Bill
Cave Creek Arizona
2013 JKR, 2018 JLR
Retired High level Management.
Just use a Diff lube, that already has the LSD Additive in it. Most do, and it will say it on the bottle, but this is only needed for LSD, BUT WORKS FOR EITHER, OR. Also go with a 75W110 Diff lube/oil in the front, and 75W140 in the rear. This viscosity in the rear, will work with either towing, or not..FYI I use Lucas, but there are plenty of different brands available.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Use 75w140 no matter which differential it is. Most decent brands have LSD additive in them anyway.
JL Diesel
Tim
La Mesa
ā€˜22 JL Diesel Sport S
Are there wires by the hitch? If you canā€™t hook up electric to the trailer you donā€™t have a tow package.
If you have a hitch only itā€™s pretty simple to install the wires yourself. The electric should be there behind one of the rear wheel wells. Just add a trailer wire harness.
Hogdreamer
Minnesota
2019 Cherokee, 2021 Sahara Altitude
Agreed. But it's pretty easy to tell if an aftermarket hitch has been installed or if it is a factory set-up.
